Melodyne sends CPU into tailspin
Anyone else having issues with Melodyne, where in certain sessions, either instantiating, or simply moving an existing instance of Melodyne to a different track causes the CPU (total bar in System usage window) to spike to 100%, rendering the session unusable? Cpu bar essential bounces from 0% to 100% perpetually.
If I simply close the session and re-open it, Protools will still spike the same, even if I open in safe mode (all plugins inactive). Only way to correct the problem is to quit Protools and relaunch. I have plenty of sessions where Melodyne is working fine, just a few heavy VI writing sessions, where its totally choking the system. Can't seem to find out if its an interaction with another plugin. Anyone seen this? Forrester PT11.2.1, HDX2, OS10.9.3, Melodyne 2.1.2 b2 |
Re: Melodyne sends CPU into tailspin
Melodyne is pretty robust in my opinion and they keep top of any bugs.
Have you other plugs on the vocal chain(s)? Try removing those first. Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
It happens wherever I instantiate Melodyne in this session, so its irrelevant to the particular track's plugin chain. I have heaps of plugins happening due to it being a writing/mixing session. Have yet to sit down and go through the process of removing plugins from my plugin folder to whittle it down till I find the culprit combination, if there even is one. Just at the "anyone else go this issue stage". It might provide insight and save time, is all. Forrester |
And before you try removing plugin files, try trashing preferences.
If it is only happening to this one session it may be corrupt. Be careful of plugins and denomalization bugs (you can search for that on DUC). With plugins known to have this problem (like Sansamp and others) and especially with them at yhe lead of a chain of plugins (where they see digital zero/very low levels and start thrashing the CPU). |
So my findings from isolating the plugins folder is inconclusive. Started with no plugs (except the default + Melodyne) and had no issues. Slowly added plugins and found that when I added the Arturia V-Collection folder, the issue with Melodyne occurred. However, if I removed all plugins back to just Melodyne and Arturia, everything works OK. So then I started adding plugins again, and at around three quarters of the list the issue pops up again. I then removed the last bunch of plugins I just added, but still have the issue? Remove the Arturia folder and boom, issue is fixed. So rather than point the finger at Arturia, I would suggest its memory usage related, ie. when I have lots of plugins happening (irrelevant of manufacturer) the memory usage ticks over to a certain amount, which causes Melodyne to overdrive the CPU. Thats my theory anyway. Basically its not as simple as a single plugin combination in the plugins folder causing the issue. Have contacted Celemony, still waiting to hear from them. Forrester |
What is "the default"?
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
I believe he means the plug-ins that come standard (free) with Pro Tools.
Oh well, you would not be be the first person to find CPU burn issues with recent Arturia plugins.
As you pull plugins out, it seems that it can very occasionally matter that you trash prefs after doing that. You might want to try doing that. |
So have found that if I remove the Native Instruments folder, or Arturia, it will fix the issue. So again its definitely not plugin specific. As i'm using 5 or so instances of Battery & Guitar Rig, and 2 or 3 Arturia synths, I can only put it down to a memory usage problem, as when I remove one of those VI's plugins, Melodyne works as expected. Hopefully Celemony can investigate. Forrester |
BTW - I've recently run 20 instances of Melodyne Editor at once without a single issue. Even did the transfer to each instance from each track at one time. Barely moved the CPU meter.
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
Sends default to -inf preference...resetting all sends to 0 | Nathan W. | Post - Surround - Video | 3 | 07-15-2011 12:10 PM |
importing audio or midi sends ptle into tailspin | Spikerama | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-04-2010 10:48 AM |
Melodyne Users - Melodyne Editor Beta release imminent! | Driven01 | Pro Tools M-Powered (Mac) | 2 | 09-18-2009 06:31 AM |
Melodyne Users - Melodyne Editor Beta release imminent! | Driven01 | Pro Tools M-Powered (Win) | 2 | 09-18-2009 12:15 AM |
Melodyne Studio 3.2 Bridge not communicating with Melodyne -- help! | nuggitz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-08-2009 03:02 PM |
