Old 09-06-2010, 10:22 AM
Rob Warren Rob Warren is offline
Default having mixrack and still using C Layer
I have the mixrack with profile. I always thought I was limited
to just using the A and B layers for faders since the mixrack is only 48 mic inputs.
I accidentally discovered I can move channels on to the C layer.
this is great. I have all my playback devices on the C layer.
I'm not using more channels but I have it spread out a little nicer now.
I feel stupid not know this but I'm pretty I was told I couldn't use the c layer. thought I should post it in case someone else needed to know this.
so now i have instruments on A vocals on B and playback on C.
sweet!
rob in st. louis
Old 09-06-2010, 11:41 AM
emluper emluper is offline
Default Re: having mixrack and still using C Layer
Rob,
While I'm on a D-Show surface, I believe that this just became available for the Mixrack with the last software rev. While you only have 48 inputs you have access to 64 "input" channels. If you move to a system with an FOH rack, you'll have access to up to 96 "input" channels. It allow for channel multing for monitor setups from FOH and other situations where you need flexibility.
Old 09-06-2010, 03:49 PM
lmiller lmiller is offline
You could always spread channels over A/B/C/D on a mix rack. But you could only have 48 faders/channels. The new software lets you have 64 faders/channels again over A/B/C/D which is great for vocal splits for monitors.
Cheers
Lionel
Old 09-06-2010, 04:20 PM
cppi cppi is offline
I did the same with my Dshow, it's just a single stage rack with 48 inputs but if you go to options > systems > edit you can cheat it by selecting 64 channels and enabling 2nd stage rack and selecting the 49-96 input.
I will put things below there that don't need regular attention and they dont have to be at the end of the console like the old analog days.
Old 09-06-2010, 06:59 PM
MartyBee MartyBee is offline
Yes 2,81 added this feature recently to mix rack
Old 09-10-2010, 01:58 PM
Brent Lind Brent Lind is offline
I don't imagine it matters either way, but you don't need to enable the 2nd stage rack, it will allow you to configure 64 channels regardless.
MixRack question eytan VENUE Live Sound Systems 8 06-03-2013 11:23 AM
Mixrack + SC48 Ethernet Snake? ravald VENUE Live Sound Systems 14 08-06-2012 07:50 AM
Profile w/Mixrack or SC48? TheMAXX7 VENUE Live Sound Systems 15 11-30-2011 09:46 AM
IoX card in Mixrack system bop VENUE Live Sound Systems 10 10-20-2010 09:27 AM
MixRack Inputs 1/2 Not Working? SimonInAustralia VENUE Live Sound Systems 4 09-06-2010 06:57 PM
