Old 08-31-2010, 12:38 AM
SimonInAustralia SimonInAustralia is offline
Default MixRack Inputs 1/2 Not Working?
Recently inputs 1 and 2 to our Venue Profile MixRack system have stopped working.
I can not see anything obvious in the settings that would prevent them working, they seem to be set correctly in the patchbay matrix window.
If I change the inputs to 3 or 4 for example for a particular channel, then I get input, but changing it back to 1 or 2 gives no input.
Is there anything I might have missed that would prevent inputs 1 and 2 from working?
Thanks,
Simon
Canberra
AUSTRALIA
Old 08-31-2010, 11:36 AM
Kenmillerjr's Avatar
Kenmillerjr Kenmillerjr is offline
Default Re: MixRack Inputs 1/2 Not Working?
What is feeding the Mix rack? Is it just pure analog lines from the stage or is there some type of digital split you have which is converting digital to analog to the console?
Ken Miller, Jr.
Audio Engineer
Southside Baptist Church | Warner Robins, GA
| VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Old 08-31-2010, 01:19 PM
Thanks for the reply Ken.
It is fed by analogue lines from stage, through a mic splitter on stage.
But I am testing with a tone generator at the MixRack itself, put a tone into 3 or 4 (or any other input) and I get signal, move the tone to 1 or 2 and no signal.
Maybe needs to go back to Avid for repair?
Old 08-31-2010, 02:58 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Hi Simon,
The quickest was to check this is to plug tone into a ch 1 or 2, and then soft patch within the patchbay to a known working input channel (ch 3 or 4 as you describe). If there's no sound, then it's likely a faulty channel or A/D converter.
Contact your reseller or Avid support and they can set things straight.
Sheldon
Old 09-06-2010, 06:57 PM
Thanks Sheldon.
Yes, seems like a faulty channel on the AI16 card.
Also swapped the ribbon cable with the AI16 card below it in the MixRack, and the faulty channel moved across to 17/18.
So have sent it back for warranty repair/replacement.
Thanks.
MixRack question eytan VENUE Live Sound Systems 8 06-03-2013 11:23 AM
Profile w/Mixrack or SC48? TheMAXX7 VENUE Live Sound Systems 15 11-30-2011 09:46 AM
IoX card in Mixrack system bop VENUE Live Sound Systems 10 10-20-2010 09:27 AM
having mixrack and still using C Layer Rob Warren VENUE Live Sound Systems 5 09-10-2010 01:58 PM
Higher channel count on Mixrack Roland Clarke VENUE Live Sound Systems 3 05-22-2009 12:44 AM
