Old 10-08-2003, 04:14 PM
Adagio12 Adagio12 is offline
Default Adjusting tempo with audio
Is it possible to adjust the tempo for an audio track in LE?
I have no probs doing this with Midi data in the transport window.
I am trying this with beat/bar oriented electronica divided into audio regions.
I have successfully mapped out a grid using one bar with the identifybeat command.
I've also tried inserting a tempo event at the beginning.
Still no joy, can anyone fill me in?
Old 10-08-2003, 04:54 PM
RinnyTin RinnyTin is offline
Default Re: Adjusting tempo with audio
If you want to change the tempo of a performance, you have to expand or compress the audio region. Check out the Pitch 'n' Time plug from Serato.
http://www.serato.com/products/pnt/
Old 10-09-2003, 04:10 AM
Homebelly Homebelly is offline
Depending on how big your original loop or region is the TIME EXPANSION/COMPRESSION plug in the audio suite menue works fine,,
if you go to the digi main home page and folow the links to digizine under the LE BOOTCAMP section you'll find a great tutorial by Joe Gore,,
basicly you set it up to be used exactly as you would the Identify Beat dialogue,,you tell it the original tempo of the region,,how long it is,,then the BPM you need it to become,,
I find the digi plug works fine for doubling the tempo,,and is better than okay for taking,say,a 100 bpm loop and making it 150 bpm,,after that it starts to sound a bit odd,,but even that can work well somtimes,,
It's not to bright at stretching vocals or any kind of melody based region,,but then most arn't,,in my opinion,,they all introduce strange anomalys and artifacts,,best thing i've heard for this is MELODINE,,or LIVE,,
Old 10-09-2003, 04:16 AM
kmshroom kmshroom is offline
audio in PT is time-stamped (not bars:beats), so changing the tempo is not going to affect the placement of audio regions.
as has been mentioned already, one (lossy) way is to use a time compression/expansion plug-in (like the DigiRack one) to change the tempo of your audio.
you cannot find peace by avoiding life
Adjusting tempo and it makes it out of sync! nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 06-10-2010 11:15 PM
Adjusting Tempo crownstatus Pro Tools M-Powered (Mac) 7 07-18-2009 05:31 PM
adjusting the tempo of an imported audio track erocker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-02-2009 10:48 AM
Adding drum wav files and adjusting to session tempo? TsonicTsunami 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-01-2008 04:05 AM
adjusting bar/beat markers on tempo mapped session otto Tips & Tricks 0 08-30-2001 03:19 PM
