Cable for J-Station
I want to connect the Johnson J-Station I just recieved straight to the Digicard.The J-Station has the s/pidf output.Is the cable I need just called a s/pidf cable? What kind of cable do I ask for at guitar center?Thanx.
I also was wondering about balanced versus unbalanced cables.Does this mean mono(unbalanced) or stereo(balanced)?? DJ
6969 |
Re: Cable for J-Station
it might be the "spdif"-cable... make it shure that it´s not only a chinch... i think the spdif-cable has 75 ohms and the chinch less or more... don´t know exactly anymore... but make shure the digital-cable...
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD |
Just make sure its 75 ohms.it will be a single cable with rca type connectors.you can get by with video cable but would suggest perhaps a good directional monster,studio link etc.
I don't know if anyone is interested,but the J-Station is $99 at musicians friend.Thanks for the help.
DJ
6969 |
Hello
I can't use my J-Station until my friend comes over this week. I just wanted to ask one more question before he comes over. Is there anything I need to make sure is checked in the setup box in PT when I'm using the spidf input? This is probably easy,but I just want to make things as painless as possible when he comes over. I appreciate the help. DJ
6969 |
Make sure to check the S/PDIF input box under the Setups-Hardware Setup menu.
Setups -> Hardware -> Sync Mode -> S/PDIF (RCA) Should work fine. Never had any problems with my J-Station. |
Make sure the session is set to the correct sample rate. I never use my J-Station's digital I/O (or at least very rarely, since I prefer to use its line outs, my converters and have the Digi 002 clocked via incoming lightpipe with a Lucid GENx6), but I THINK it transmits at 24 bit / 44.1 KHz. So make sure your session is set correctly or you'll have problems. Other than that and the Setup | Hardware | Sync Mode | S/PDIF and the use of the proper cable (75 Ohm RCA connector S/PDIF) you should be fine.
Phil O'Keefe PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. |
Thanks for all your help folks
I have the 001 and I am under the immpression that if I connect via s/pidf then I would be bypassing the converters in the 001 box and get a possibly better recording of the guitars. Am I correct on this? I don't have any outboard converters or pre-amps complimenting my 001 at this point. Thanks again my peeps of the DUC. DJ
6969 |
Yes, when you route audio into the Digi 001 (or MBox or 002 / 002R) via a digital input (S/PDIF / Lightpipe), then you are bypassing the Digi's converters.
WTT: flex cable for short digilink cable | tripstation | Buy & Sell | 1 | 08-21-2012 01:22 AM |
Need Y cable for Session8 XL ou cable pinouts | musicabos | Digidesign Hardware & Software | 0 | 07-29-2005 04:09 PM |
Is cable for 24|Mix -> 882/20 standard SCSI-2 cable? | Last Legend | Pro Tools TDM Systems (Mac) | 2 | 01-18-2003 12:36 AM |
Digi 001 I/O Cable Question (need longer cable) | M@tt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-16-2001 01:47 PM |
Digi 001 I/O Cable Question (need longer cable) | M@tt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-15-2001 10:08 PM |
