Old 11-30-2022, 09:54 AM
RichrdC RichrdC is offline
Default Playback engine does not support sample size 96kHZ
Hello to all,
I'm wracking my brain on how to fix this error. I'm not able to open a session as this error pops up when I first go to open the session. I have an MBOX, it's set to 44.1kHz... It seems the session is at 96kHz. I can't tell you how that happened since I don't think I've ever changed any setting from the 44.1 kHz. Other sessions open fine so I don't think I have an issue with the speaker configuration.. I'm on Pro Tools 2018.4, Microsoft Dell, 32 Gig Ram, QconProX DAW and the MBox.. I've been trying for awhile now and just can't find the path to fixin' it.. Thank you in advance for ANY thoughts..
RichrdC
Old 11-30-2022, 11:25 AM
Default Re: Playback engine does not support sample size 96kHZ
I thought I'd just come back and say that I can't open many sessions because this error message pops up when I try.. I see lots of posts about opening an new session and then importing session data from the one that isn't playing into the new session, but in this case, I can't get to the session data that I'd import..
Does the DAW have it's own sample settings? Of course, why would some of my sessions play fine, while others don't?
Old 11-30-2022, 12:42 PM
What Setup>Playback Engine are you actually trying to use? Check, do not just assume it is the Mbox.
Make sure Windows or other apps are not trying to use the same interface/Mbox.
(and BTW it's sample rate not sample size)
Old 11-30-2022, 01:12 PM
I suspect Darryl is on it and Windows is trying to use the Mbox as its default playback device. Even if this gets fixed, it can get reset by some Windows update or a driver update, so its worth checking even if you are certain you changed it. If the session is indeed at 96K, create a new empty session at your desired sample rate, import session data and let it convert from 96K.
Old 11-30-2022, 04:19 PM
unkJE's Avatar
unkJE unkJE is offline
Originally Posted by Darryl Ramm View Post
What Setup>Playback Engine are you actually trying to use? Check, do not just assume it is the Mbox ...
Hold down the ‘N’ key while launching Pro Tools – this will open the Playback Engine.
If ‘Mbox’ is not listed as ‘Device’ – use the drop-down arrow to change it to ‘Mbox’.
Restart computer.
Launch Pro Tools.
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor
Old 12-02-2022, 12:29 PM
Hi Darryl,
Yes it is the Mbox listed.. I'm not sure how to check if Windows is trying to use
Mbox.. Guess I'm more computer illiterate than I thought..
Old 12-02-2022, 04:33 PM
The Weed's Avatar
The Weed The Weed is offline
Control Panel>Sound
On both the Playback and Recording Tabs, set your onboard soundcard, usually a RealTek, as the Default and Disable any instance of the Mbox.
FYI, Pro Tools Sample Rates are whole number multiples of 64.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-31-2023, 06:18 PM
Happy New Year to all... I'm revisiting this thread because there's one thing I can't figure out. I understand opening a new Session & importing audio to it. But if the audio is in a session that will not open because the error message comes up first thing, how do I get to the track data within the session displaying the error in order to import it??
Old 12-31-2023, 07:07 PM
Have you fixed the original problem? Followed the directions above? There is no reason you should not be able to open a session at 96kHz or any sample rate the interface supports.
You can also create a new session at any sample rate, and import audio content into the session from other sessions, using sample rate conversion you control in the import dialog panel. If your session was well organized the audio files in the session would be in a folder in the session folder, but where they is up to what you did.
But you should focus on getting things working as they should.
Current Playback Engine does not Support a Sample Rate of 48 Hz yasita Windows 7 12-27-2017 05:58 PM
the current playback engine does not support a sample rate of 44.1 khz bzerk Pro Tools 12 11 05-03-2015 07:13 PM
playback engine don't support sample rate 48 khz evgpro Windows 15 05-04-2014 09:10 PM
Playback engine does not support sample rate RichrdC Pro Tools M-Powered (Win) 0 08-16-2012 06:05 PM
The current playback engine does not support a sample rate of 44.1 khz murdafew Pro Tools M-Powered (Win) 4 05-14-2010 03:21 AM
