Why use black magic devices to playback video instead of just playback in pro tools?
Hi there,
Just wondering : we can playback the video in pro tools session and put the window on another screen, what’s the reason we should spend more money on black magic or Aja devices to have pro tools output video thru that? Thanks
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt |
Re: Why use black magic devices to playback video instead of just playback in pro too
You can do a direct video out (this one may not be important to most people) (ie, hardware video online that outputs only the picture that can be fed to screens and projectors)
You can genlock the picture (if the playback video card supports it) so that the picture is in frame sync. This one is important to post-production and dialogue editors to keep absolute sync. The video offsets in Pro Tools are nowhere near as consistently accurate as actually have a playback video card and Pro Tools both on genlock/black burst sync (need Sync HD also for Pro Tools to do this)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Great question. For years, video playback ate too many system resources and so offloading the movie to an external codec, like a Blackmagic or Canopus or one of the other FW/TB/USB boxes, helped ProTools operate more freely. I used a Canopus for years, then switched to a Blackmagic, but for the past year I've been sending video to a 2nd monitor which is connected to my trashcan Mac's HDMI port and it works swimmingly. AND there's the option of throwing plugin windows over to that monitor if the main desktop gets crowded. There has been no real downside to this.
Another advantage is that I no longer need to convert videos to DV, since that's what the external boxes preferred to work with. When a video comes in, I simply import into ProTools, drag to the other window, hit Full Screen and that's it. So, unless you have a slower machine and need to get video processing off your main system, or if you don't have the physical outputs for a dedicated TV, you can safely forgo the Blackmagic. We've done this in four or five different rooms which once used Blackmagic or Canopus boxes and there's no going back in any of them. |
Not to mention the benefits if has for stuff like ADR, working/viewing with clients, or even creativity. The last is probably quite subjective, but I do like having a playback monitor that is more associated with my audio monitoring than my Pro Tools workspaces. The former is larger and mounted in a fixed location - more or less treated as 'the end game', while I have a pair of monitors on arms that I can drag forward, etc for the Pro Tools edit and mix window. I do still playback video from within a window in Pro Tools for editing, etc... but I do often get amazed by how much sync, or the tone and feel of work changes when moving to a bigger, dedicated screen.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
No Video Playback (Black Video window and thumbs) | winkelement | Pro Tools 12 | 13 | 03-17-2016 11:03 AM |
PT 11 video and MXF files using Black Magic cards | paulo m | Post - Surround - Video | 5 | 08-19-2013 05:50 AM |
Video codec for Black Magic Deck Link | actualsizeaudio | Post - Surround - Video | 23 | 07-12-2013 06:26 PM |
Black Magic Intensity & HD Video Codecs | mikevarela | Post - Surround - Video | 7 | 01-26-2010 01:52 PM |
Black magic video sync | s0und80y | Post - Surround - Video | 2 | 05-09-2007 03:16 AM |
