Old 12-17-2018, 06:01 PM
Karma180 Karma180 is offline
Default Open .pts (Pro Tools 6.4.1) in Pro Tools 2018
I'm about to do a major hardware/software upgrade to my recording rig, currently a Digi001 and Pro Tools 6.4.1. What can I expect to happen when I try to open (or import?) .pts files with Pro Tools 2018? For example, will my clips maintain their place on the timeline, will my mix automations be intact, my fades, tempos, gains, etc ...
Thanks,
Karma
Old 12-17-2018, 06:24 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Open .pts (Pro Tools 6.4.1) in Pro Tools 2018
You need to open in PT10 and save in .ptx format first
Janne
Old 12-18-2018, 06:57 AM
If your sessions have audio files that are SD2 (Sound Designer II) files, then be sure to convert all the sessions and audio files to WAV before moving to a newer Pro Tools or OS.
Scott Gatteño
Old 12-19-2018, 07:57 PM
Thanks for the info but ... how do I open the 6.4.1 .pts files first in PT 10 when I want to go from 6.4.1 directly to PT 2018?
Yes, all of my years of sessions are wav files and pts sessions.
What I'm after is if the integrity of my sessions will be maintained;because if not and if its going to be a complete overhaul of my thousands of files its not worth it and I will just stay with my Digi001 and PT 6.4.1 ... Is there anybody with the expertise to address my stated concerns at the beginning of this thread?
Thanks again,
Karma
Old 12-19-2018, 08:29 PM
WKG WKG is offline
Out of curiosity I just opened several older .pts 6.9 sessions with no problem in 2018.7.
Are .pts 6.4.1 different?
I7-4930K, X79-Deluxe, 2133 32 GB,
GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2,
Win 10 Pro, PT Ultimate 2020.12 Studio One 5 Pro, REAPER 6
RME, Daking, Heritage, ISA, Sytek
Old 12-19-2018, 09:39 PM
J.D. Andrew J.D. Andrew is offline
If you have the old system and it works, don't get rid of it. Just keep it so that you always have the backup. And then experiment with what works as you transfer a session over and open it on the new system.
There will be conversions that you'll have to try, and a lot of plugins will not recall the settings from the old version. But there is no real way to keep things exactly as they were unless you keep that system.
Old 01-19-2024, 07:34 AM
terracestudio terracestudio is offline
Did you ever figure out how to convert your pts sessions into the newer versions of pro tools?
It's a crime that the older stuff gets left behind by pro tools.
Old 01-19-2024, 07:37 AM
JFreak's Avatar
As always, you cannot make an omelette without breaking eggs. PT6 is +20yr old already. Even 64bit PT (v11) is +10yr.
Janne
Old 01-23-2024, 12:17 PM
If you have a working older setup that can open these old sessions, open each session> consolidate all audio back to 00:00:000 and export these audio files for each song. Those can be imported into any DAW(including any newer version of PT) and edited and mixed without issue. Yes, the old sessions SHOULD open in newer PT, but you never know. Of course, if you are making a major upgrade, the sensible way to do it is to leave the old system untouched. Build your new system with current software and copy some sessions over to the new system so you can try and open them. If nothing works, refer to my initial suggestion(sometimes starting from scratch is the best way to go when revisiting old sessions)
Old 01-24-2024, 08:14 AM
smurfyou smurfyou is offline
Current PT can open them. There was a few years where it was a missing feature.
~Will
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Pro Tools 2018 with Pro Tools Control on iPad - connection problem JacobSoundStudio Pro Tools 2018 4 06-25-2018 01:24 PM
Pro Tools 12.7.1 to Pro Tools 2018 Questions robert-morton Pro Tools 2018 6 05-02-2018 06:10 PM
Latency with Pro Tools Ultimate vs. regular Pro tools 2018 DualCoreX2 macOS 5 04-25-2018 08:17 AM
