Old 09-22-2017, 07:06 AM
Feinbeat Feinbeat is offline
Default Artist Control Softkeys stopped working on Ableton
Hi
after a eucon crash, all Softkeys and surface buttons stopped working on Ableton.
Also a complete new install of the eucon software didn´t change anything.
I have tried the 3.6.1 and the 3.6.0 which worked for a few days.
My Setup:
Win System preferences: Added Ableton with MackieControl 1-4
Ableton:
Added Artist Conrtrol as Mackie Control
Added Artist Mix as Mackie Control XT
Added Artist Mix 2 as Mackie Control XT
Activated Tracks and Remote for all Eucon Midi Channels 1 - 3 as Input and Output
Did a new Ableton Template, but no Softkey or Surface key will work anymore.
The Faders work goog.
Can someone please help me getting this fixed?
I need it for work.
Old 09-22-2017, 07:11 AM
Default Re: Artist Control Softkeys stopped working on Ableton
For testing, I did a new Template only with this COntrol
Code:
   <Section ID="1" NAME="">
      <Bank ID="0" SIZE="16">
        <NormalKeys>
          <Control ID="SoftKey1" TYPE="SmartSwitch">
            <Label FONT="Arial Bold" FONTSIZE="12.0000" NAME="Track" NOTEXT="1" TYPE="Text"/>
            <CommandSet SUBTYPE="OneShot">
              <Command ID="1" INDEX="0" LCTL="ON" TYPE="Key">t</Command>
            </CommandSet>
          </Control>
Button this simple Key-Command: CTRL + T (new Audio Track) doesn´t work.
Old 09-22-2017, 07:23 AM
also the same in Cubase via EUCON Protocoll....
I begin to hate this Avid Series....
Old 09-22-2017, 08:04 PM
EddieJones's Avatar
They don't display at all on the TFT or they don't operate? Do other things on the TFT work? Knobs values? Do the faders on the Control work ?
Old 09-22-2017, 09:24 PM
t1mtnntgn t1mtnntgn is offline
Old 09-22-2017, 11:14 PM
Thx for the reply.
Yes, the faders and knobs do work, only the Softbuttons do nothing, but there all there on the screen.
It´s really strange.
Old 09-23-2017, 07:43 PM
EddieJones's Avatar
Sounds like it sees the Softkey Appset but they aren't getting through to Ableton. Do softkeys work in other Apps ?
Old 09-24-2017, 03:37 AM
the same in cubase...
meanwhile i had to reinstall win completely to finish some work.
tomorrow i will try to install eucontrol again and hope it will work.
What file stores the softkeys settings on the Artist Control? K_BCN Artist Series 10 10-07-2017 12:49 AM
Avid Artist Control + Mix - Ableton on Win 10 Feinbeat Artist Series 10 09-17-2017 03:15 AM
Hotkey/MIDI Message to switch Touchscreen Softkeys on Artist Control + PT | Control jimmivalentino Artist Series 3 09-07-2017 12:17 PM
Copy/Paste or Move for Artist Control softkeys? hanksinclair Artist Series 17 01-30-2016 09:52 AM
Mousepad on the Artist Control under softkeys YYR123 Artist Series 0 06-06-2014 01:28 PM
