JoeMeek ThreeQ Preamp through MBox 2?
I'm looking to purchase the JoeMeek ThreeQ mic preamp for my DAW. I've heard that the only way to completely bypass the pre's in the MBox is to go into the MBox using S/PDIF. I don't think the ThreeQ has such an output. Are there any other ways to bypass the pre's in the MBox if I was to purchase the ThreeQ?
Thanks, Broc
http://www.myspace.com/freedombydeath6789 __________________ "There is nothing in the world so much like prayer as music is." ~William P. Merrill __________________ Pro Tools LE 8.0.1 | MBox 2 USB | XP MCE SP3 |
Re: JoeMeek ThreeQ Preamp through MBox 2?
I know the Twin Q has a S/PDIF out, (I have one) and it may even make more sense. Not sure about the Three Q, shouldn't be that hard to check out the back.
www.rickqueststudio.com |
There 's no output for S/PDIF, but I wanted to work around that possibly?
Broc
Okay, checked it out for you, first of all you do know it's 1 channel, correct? The 3Q stands for compress, Eq, and mic pre. And no, it does not have digital outputs. There is not a lot of quality pre's for $250 but you may find something like an Art or Behringer w/2 channels and a S/PDIF out. The twinQ like I suggested, is a nice piece but up there in price. You may find a used one for around $500.
2 things to think about. With a USB Mbox(all except the "PRO" version) the SPDIF port is not auditioned with the MIX knob. This means you MUST have a computer potent enough to record at the lowest buffer setting(probably 128). The other thing is; if you do use an external preamp without SPDIF, the best you can do is go in with a TRS cable(TRS into the Mbox line input) and bypass a gain stage. That doesn't truly bypass the Mbox pre, but its as close as you can get without SPDIF(and it should retain the character of the external preamp well enough). Personally, I would spend the cash on other things like maybe a great microphone or some good acoustic treatments for the room, or maybe a ice bundle of plugins. Okay I guess that was 3 thing to think about
Thanks for all the replies guys! I previously had an ART Digital MPA II. Started immediately having problems with it. The blue light that illuminates to show that the digital out is working begins to blink when I switch the clock source to S/PDIF in Pro Tools; then it begins to make a ticking sound and the blue light goes away. I made sure I had the correct dither/sample rate the same as in Pro Tools so that's not the culprit. Overall I'm dissatisfied with problems right out of the box. So I was looking to try another preamp. The JoeMeek ThreeQ seemed like a great addition to my DAW considering all the reviews I've read about it performing exceptionally well for it's price range. I need a nice mid-grade pre, one that can work with an MBox 2 to bring that warmth and character to vocals mainly. Didn't want to spend over $400, about what the Digital MPA II costs. Thought it was a neat little channel strip/preamp to use for my projects. Guess I'll research a little more and see what I can find.
Thanks, Broc
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
I have already switched the clock source in Pro Tools to S/PDIF. I did that when I first hooked up the Preamp. Still experiencing clicks and pops, or it won't work at all.
I don't understand, you don't even have an external source yet do you? If so what are you using now? This could be your problem.
I thought the ART Digital MPA II was the clock source? Do I need to have a separate external clock source by itself as well? I don't understand either.
Broc
Mbox 2 pre-amp vs a mic preamp | GuitarSlinger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-31-2008 05:33 AM |
Mbox Mic Preamp | thewordsband | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-04-2005 06:40 PM |
JOEMEEK ThreeQ or RNC?? | Ruben_B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-08-2005 08:48 PM |
Mbox preamp/ new preamp | Antihero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-23-2003 07:31 AM |
Joemeek preamp vs. FMR RNP | TrippSTRAT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-23-2003 07:02 AM |
