Old 05-11-2010, 06:23 AM
studer studer is offline
Default Is 003 Factory acceptable for Audio Post?
Hi there,
I'm just getting back in to Sound Post Production for film and video and just wanted to know if the Digi 003 Factory is something that would work for this application. I was looking at this system vs the Projectmix I/O. I want something that is capable in mixing a 5.1 Audio track. Is it possible with this gear.
Thanks
Old 05-11-2010, 06:38 AM
Dism Dism is offline
Default Re: Is 003 Factory acceptable for Audio Post?
Originally Posted by studer View Post
Hi there,
Thanks
Digi 003 is certainly a viable Post option with the Complete Production Toolkit. 128 tracks, 5.1 surround mixing, timecode, etc.
Project Mix is probably capable of these things, but NOT with Pro Tools.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 05-11-2010, 07:01 AM
I was under the impression that ProTools was the industry standard for this type of operation. It's not suited to Audio Post for Film?
Old 05-11-2010, 07:06 AM
Digi 003 with Pro Tools LE and Complete Production Toolkit.
Project Mix will only work with Pro Tools M-Powered which does not support the Complete Production Toolkit or 5.1 surround sound. It may suit those needs with another DAW, however.
D
Old 05-11-2010, 07:20 AM
Ahh, I understand now lol. Projectmix can only operate with M-powered version then? It's not something that can be updated? Do you have any other recomendations? Sorry, I've been out of the loop for quite some time
Old 05-11-2010, 07:26 AM
It's just the limitations of M-Powered. The only toolkit available for MP is the Music Production Toolkit, which gives you expanded track count, and a few other options, but really isn't geared for film.
PTLE can be upgraded with the Music Production Toolkit, the DV Toolkit (which is more geared for film, with TC, Digitranslator and a few other niceties, but no 5.1) and the Complete Production Toolkit, which is what I believe would be suited for your needs.
D
Old 05-11-2010, 07:30 AM
nst7 nst7 is offline
If you plan to do anything with 5.1, you will need the Complete Production Toolkit (the DV Toolkit does not do any surround). By itself it's $2000, but they make a bundle called 003 Factory Complete, which combines everything and saves you some money.
Old 05-11-2010, 07:54 AM
promixr promixr is offline
You might also think about how you are getting video into and out of Pro Tools and video monitoring and layback - you might consider something like an Avid Mojo for this... not sure what your workflow entails...
http://imsproav.com/main/search/DIGIDE99303423700.html
Eddie Sullivan
Long Island Mac Tech
http://long-island-mac-tech.com
[email protected]
631 786 3924
Freelance Mac/Pro Tools tech for hire. Metro New York Area.
Old 05-11-2010, 09:07 AM
Everything will be Shot on a Sony EX3 and edited on a Mac using Final Cut. Audio will be done on a PC. Im concerned about Time Code. Ive always used external SMPTE generators
Old 05-11-2010, 12:52 PM
It almost seems as if M-Box is more what Im after
LE Factory Bundle for Post soundart Post - Surround - Video 5 05-05-2007 03:51 PM
acceptable latency? therecordinghouse Tips & Tricks 4 05-10-2006 07:55 AM
acceptable volumn problem johnmo2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-15-2005 10:35 AM
A normal/acceptable amount of crashing? east3rdst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 32 11-07-2001 09:45 AM
multiple compression layers—acceptable? dex Tips & Tricks 2 06-29-2000 12:48 AM
