DAE Error -1127 Pro Tools HD 2
Hi Guys,
I just installed Pro Tools HD 2. but when I try to launch after loading all the plug the error message coming up and everything shut down. I use a Mac Pro with snow Leopard (I already updated to PT 8.03) with 192 I/O. Somebody knows what could be, I try to look up the error in Google and Digidesign but nothing come up. Thanks in advance |
Re: DAE Error -1127 Pro Tools HD 2
Hard to say exactly without more information! you could try removing all plugins from the plugs folder except the stereomixer.dpm and see if pt boots up! system drive/library/apps support/digidesign/plugins just move them to another folder for storage. Trashing the prefs might help! has this install ever booted up? how did you go about the install? here's the troubleshooting thread... http://duc.digidesign.com/showthread.php?t=240754 Chris
Hi Chris thanks for the reply I'll try to give you more info:
The Installer never worked I installed myself following the set up instructions. The digitest it's ok no error founds, it's possible that it's the Flex cable incorrectly plugged? thanks Matt |
Hi all in case you get the same error the problem it's originated by a loose Flex Cable.
Now everything work fine. Thanks |
DAE Error - 1127 | fishburg | Pro Tools TDM Systems (Win) | 18 | 05-11-2015 10:45 PM |
Dae Error -1127 WTF is it??? | djkrayz | Post - Surround - Video | 2 | 03-24-2010 11:07 AM |
DAE -1127 error | JJC | Pro Tools TDM Systems (Mac) | 2 | 02-14-2008 04:37 PM |
DAE error -1127 Help!? | scbrown | Pro Tools TDM Systems (Mac) | 3 | 05-16-2007 10:56 AM |
DAE error 1127 ? Help Digi | sctstudios | Pro Tools TDM Systems (Mac) | 2 | 01-07-2007 11:31 AM |
