Old 07-11-2007, 06:41 PM
vjk vjk is offline
Default AUDIO FILE NAMING
I was wondering if there's a more defined way of naming Audio files that get recorded - eg: I know that the Track Name (if named before recording) will be what the audio file is called within that songs Parent Folder, but is there a way of associating the SONG NAME with each audio track that gets recorded - instead of just having GUITAR-1 / GUITAR-2 / LAP STEEL / etc etc. (other than putting the Song Name on each Track)
As these are common to most songs I record, if things get lost for whatever reason, there will be zillions of "GUITAR-1" files but no way of associating them with a song other than playing each file and trying to figure out which song it came from.
I hope I've explained this clearly, and if someone has a suggestion I'd love to hear it.
Thanks in advance.......
PT MP 7.3.1cs3,Delta 1010LT,Yamaha MG16/4, AudioTechnica 20/20,Behrenger C2 Mics,Shure SM58,Windows XP Pro,P45G Chipset,P4 3Ghz,2Gb RAM
Old 07-12-2007, 05:32 AM
Gunnell Gunnell is offline
Default Re: AUDIO FILE NAMING
The only thing I can think of is renaming every audio file in the window on the right. That's the same amount of work as including the song name in the track titles before recording though. I'd like to hear a better way myself.
OSX 10.8
Pro Tools 10 / 11
Sapphire Pro 40
Mac Pro 2.66 GHz Quad-Core Intel Xeon
10 GB 1066 MHz DDR3
Old 07-13-2007, 07:51 PM
vjk vjk is offline
OK...thanks....so do you mean change the names in the "Regions" list on right side of the Edit window?
If so, does this also change the Audio file name on the Hard Disc where it is stored?
Naming of clips when audio file ends with a number John Link macOS 5 06-02-2013 04:36 PM
Elastic Audio file/region naming jem777 Pro Tools M-Powered (Mac) 0 06-05-2009 04:25 AM
File naming? soundguydave Pro Tools TDM Systems (Mac) 4 09-23-2008 06:15 PM
Naming file crashing PT Farmer Dave Pro Tools TDM Systems (Mac) 8 12-03-2006 01:08 PM
file naming ofsaints Post - Surround - Video 2 11-28-2006 10:05 AM
