Old 10-17-2000, 01:02 PM
sroewe sroewe is offline
Default Capturing Audio & Video w/ DC 30 + (Audio Sync Problem)
Does anyone capture audio and video with their dc 30 + card to play movies with protools. If so, do you experience the audio being out of sync with the picture?
Old 10-17-2000, 02:52 PM
doug sjostrom doug sjostrom is offline
Default Re: Capturing Audio & Video w/ DC 30 + (Audio Sync Problem)
I use a 30 not a +, but I have no probs. Are you using Premiere? There is a setting, Movie Capture - Record Settings - Conform movie to ___. Must be set to 29.97. Hope this helps. If not explain your software settings etc.
DS
Doug Sjostrom
Old 10-17-2000, 05:07 PM
irwintino irwintino is offline
I'm using an Aurora Fuse Card with Premiere v4.2.1 (I think). Once you Conform Movie (as the previous reply mentioned), it slams back into sync.
BTW, has anyone figured out how to properly conform a movie in Premiere v5.1 (full version)?
Old 10-18-2000, 10:09 AM
I use 4.2.1 also. I see no need to change, but isn't the process the same?
Doug Sjostrom
Old 10-18-2000, 11:52 AM
iamstudios iamstudios is offline
I have the same question about conforming in Premier 5.1. We never had any releases before 5.1 so can't seem to find the conform movie-button. Does somebody know how it works? Any help would be greatly appreciated!
thanks
Barnier Geerling www.imperium.nl
i am studios b.v.
www.iam-studios.com
audio post production. music composition. sound design
Old 10-18-2000, 02:40 PM
trakbytes trakbytes is offline
I have tried to capture movies with Premiere 5.1, and can't get them to sync up in Protools-they always drift. The conform movie function doesn't seem to exist. I have spoken with other users regarding this issue, and they have all given up on Premiere 5.1. Stay with Premiere 4.21, and you'll have no problems.
Anyone tried any other capture software??
Bob
Save early and often! (or once a day whether you need to or not...)
Old 10-18-2000, 04:00 PM
I just got the word for Premiere 5.1. Somewhere in the read me doc are about two sentences that talk about creating and ini file that will force the movie to conform to 29.97. I have 5.0 and the upgrade to 5.1 so I may not have this, but somebody else take a look and post the info if I don't find it first.
DS
Doug Sjostrom
Old 10-18-2000, 05:10 PM
Here it is cut and pasted from the doc:
If you have problems with duplicate or misordered frames, you can use
a setting in the Prem50.ini file to enable Auto-conforming. A copy of the Prem50.ini file has been included for you to use as a template. You can find this file in the Setting folder, located in the Adobe Technical Info folder on the Premiere Application CD. Because this file is locked, you will not be able to edit it even if you drag it to your hard drive.
1. In the Premiere folder, open the file Prem50.ini if it exists. If the file does not exist, open SimpleText and create a new empty text file named Prem50.ini.
2. Add the following text to the file (case is important, so add the text exactly as shown).
[parsecodec]
PGVV=1
3. Save the file into the Premiere application folder and restart Premiere.
Someone w/ Prem 5.1 try this and report back!
DS
Doug Sjostrom
Old 10-18-2000, 10:45 PM
skeezer skeezer is offline
my solution is to use final cut pro with machine control. i'm testing that setup right now. heck with this freewheeling stuff. i want picture to be pro too!
i'll report back
Old 10-23-2000, 03:41 PM
I haven't found a solution yet. The info from the read me file pertains to a different capture card. Seems like the audio is alwyas a bit out of sync with the DC30 +
PT8 capturing video mojo in sync redbox_s2 Post - Surround - Video 1 03-12-2009 05:02 AM
Capturing video and audio problem sebamars 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-25-2005 09:23 AM
Problem with Audio and Video sync Dave Bechtel Post - Surround - Video 4 04-17-2004 12:57 PM
stupid me! capturing audio & video benderbro Post - Surround - Video 1 08-25-2003 09:46 PM
Problem capturing audio for Snapz Pro Movie hughesdigi General Discussion 0 07-17-2000 10:34 AM
