Old 07-01-2019, 03:09 AM
Manne Kjellander's Avatar
Manne Kjellander Manne Kjellander is offline
Default Different loudness readings with different meters
Hi!
I have two issues that are kind of related.
First I'm trying to measure the loudness and true peak of a 5.1 feature film mix (for compliance with EBU r128). I get the following values from three different meters:
NUGEN LMCorrect -23.3 LUFS -1.2 TP
Youlean Loudness Teater 2 -23.1 LUFS -0.8 TP
Avid ProLimiter Loudness Analyzer -22.7 LUFS -1.5 TP
How can this be? Which one is correct?
The second issue is that I use a Pro Limiter on this mix. It's at -1.5 (both threshold and ceiling). Still two of the meters shows peaks above that. Makes sense that Avids meter shows -1.5, just as the limiter is set. However it sounds unlikely that NUGEN would show .3 db off!? Don't know about Youlean but from my understanding NUGEN is a widely used and respected brand.
Very confused here. Any help would be very appreciated!
/Manne
Pro Tools HD Native - 12.6
Mbox Pro 3
macOS - v 10.11 (El Capitan)
Mac Mini - Late 2012 - i7, 16 GB RAM
Old 07-01-2019, 03:40 PM
henningaround henningaround is offline
Default Re: Different loudness readings with different meters
A while ago I used the Flux Elexir as TP Limiter. I had to set it to a threshold of -3,8 to never have peaks higher than -3dB. Since then I never had the feeling that I can trust a software limiter completely. I always set a threshold lower even if I now use ProLimiter or NuGen ISL.
Old 07-02-2019, 09:28 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
There is no "precisely correct" meter because of the wide variation in program material and looseness in the R-128 spec. It's a wide world of "sort of." For that reason, it's a bad idea to really push the limits.
Bob's room 615 562-4346
Georgetown Masters 615 254-3233
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 07-02-2019, 10:37 AM
Thanks for informing me! Thats the conclusion I reached from digging into it as well. For some reason I was under the impression that the r128 standard was absolutely unambiguous, but it's not. Even the algorithm for calculating TP is up for debate as Julijan Nikolic of Youlean Kindly informed me. It's good to learn!
Mbox Pro 3
HTML code is On
Help me make sense of these ADC readings ... katerkarlo Pro Tools 12 31 09-23-2018 02:05 AM
iZotope RX Loudness Control - Automatic Loudness Correction for Broadcast iZotopeInc AAX Plug-ins 0 05-21-2015 10:16 AM
Loudness Meter - different readings Meads Post - Surround - Video 28 11-21-2014 04:04 PM
FS: PAIR of Dorrough 40-C2 Loudness Meters $499 shipped joepopp Buy & Sell 3 06-15-2014 12:35 AM
CALM Acts Audio Loudness, Average Loudness, Program Loudness levels... help needed qr2r Post - Surround - Video 12 11-10-2011 01:41 AM
