Old 02-09-2016, 05:52 PM
adam79's Avatar
adam79 adam79 is offline
Default Pro Tools 12.4 Activation Issue
I'm having an issue opening Pro Tools. It prompts me to log into my iLok account and activate a license, but says there are none in my account. I double checked what's on my dongle and my PT 12 license is there and active.
When I bought the PT 12 upgrade it came w/ a 12 month upgrade/support plan that ended last month. That's the only thing that has changed on my iLok, but it shouldnt have any impact on opening PT and it working properly, right?
I recently downloaded 12.4, but I took a small break from recording and forget if this is my first time trying to open this version (12.4).
Any ideas on what's going wrong, suggestions on what to do?
I'm running OS X 10.10.5 (Yosemite) and using a UA Apollo Interface. All the firmware/software on the Apollo is up to date and working fine.
Thanks,
Adam
Old 02-09-2016, 05:59 PM
TOM@METRO's Avatar
Default Re: Pro Tools 12.4 Activation Issue
Just curious. Did your upgrade and support plan end prior to 12.4 being released?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-10-2016, 08:40 AM
adam79's Avatar
I downloaded it before the plan ended, however I forget if I installed it before, if that even matters. The odd thing is that on my avid account page it lists my plan as active although the end date is clearly marked 1/16/16.
Do you think I should try installing the previous version of PT just to see if 12.4 is what's causing the problem?
Thanks.
Old 02-10-2016, 09:22 AM
TOM@METRO's Avatar
Yes, I would give it a try.
I'm not exactly sure how the cutoffs work here, but I have asked.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 02-10-2016, 10:43 AM
adam79's Avatar
Huh, so I tried going back to 12.2.1; same issue. Then I reinstalled 12.4, but kept WiFi on w/ the dongle attached and.it opened w/o a hitch. Problem solved!
Old 02-10-2016, 11:36 AM
TOM@METRO's Avatar
I don't understand why Wi-Fi would help... but great.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 02-10-2016, 05:41 PM
jeffro's Avatar
jeffro jeffro is offline
Originally Posted by adam79 View Post
I'm having an issue opening Pro Tools. It prompts me to log into my iLok account and activate a license, but says there are none in my account...
You have an expired Pro Tools Plan license on your iLok2. Can you please Deactivate that and let us know if the problem persists?
linkedin
Pro Tools 12 Activation Issue Dalsia Pro Tools 12 1 12-18-2015 05:39 PM
Pro Tools 11 Activation Issue musicguy35 Pro Tools 11 1 10-12-2015 10:49 AM
Activation Issue with PT 10 SE Zac-Metal Pro Tools 10 2 07-20-2012 07:42 PM
Pro Tools 9 Crossgrade/Activation Issue Minimutt Pro Tools 9 17 03-05-2011 06:24 AM
