Old 04-10-2019, 05:33 PM
my-name-is-thanos my-name-is-thanos is offline
Default Audio Leveling Question
How do you make all audio clips in a track to where they all have the same amount of volume?
Old 04-10-2019, 05:40 PM
Top Jimmy's Avatar
Default Re: Audio
You can go through manually adjusting the clip gain of every clip, or you can RMS normalize the clips via the normalize audiosuite plugin.
James Cadwallader
Old 04-11-2019, 08:18 AM
Default Re: Audio
https://quietart.co.nz/defaulter/
Keep in mind that setting clips to some arbitrary RMS number will not necessarily make them sound the same level.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 04-13-2019, 02:15 PM
Default Re: Audio
Rich. I noticed that. What is the normalize even for then. So the defaulter thing is what does it?
Old 04-13-2019, 06:00 PM
Top Jimmy's Avatar
Default Re: Audio
Rich was pointing out that RMS normalization may not match the loudness from clip to clip as good as you might want. Try RMS normalization and if you’re happy with the results then don’t worry about it. Personally, I’d use RMS normalization and then make any clip gain tweaks needed as I worked through the project.
James Cadwallader
Old 04-13-2019, 11:08 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Audio
Yes - it's a great tool and can get you 90% there, but in the end use your ears. I have a client who's always looking at the waveforms saying "that clip doesn't look as loud", and I say "yeah but it sounds fine!"
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 04-14-2019, 11:07 AM
Default Re: Audio
cwsand. I get what your saying. It's like even if the wave forms match up one will still sound a lot louder than the other. Because it depends on how it was recorded. I tried to find the defaulter but its like $99. Is there somewhere I can get it free?
Old 04-14-2019, 08:57 PM
cwsand's Avatar
Default Re: Audio
The Normalize plugin is included with Pro Tools.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 04-15-2019, 06:13 PM
Default Re: Audio
I'm talking about the defaulter plugin that rich mentioned with a link. The defaulter plugin and the normalize are 2 different things. Right?
Old 04-16-2019, 07:17 AM
Default Re: Audio
Defaulter is an automated way to go through and normalize many clips to an arbitrary RMS value. It essentially just automates the Gain plugin. I do wish the Gain plug supported LKFS normalization though.
Audio Metering And Leveling Becharax General Discussion 24 08-24-2014 02:41 PM
A question about live leveling lspaulsp Eleven Rack 3 05-31-2013 03:42 PM
correct leveling? chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-01-2005 11:09 AM
Send Bus overages - leveling question? davetron5000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-17-2005 01:33 PM
Leveling Audio Tracks Gigmeister Digidesign Hardware & Software 1 02-20-2003 04:09 PM
