Old 06-05-2012, 12:03 PM
DJKeys's Avatar
DJKeys DJKeys is offline
Default Bounce Instrument Track to .wav File
I was having problems last night converting two VI tracks to audio. I have a Strike stereo drum track and could not get it routed internally to an Audio track using outputs or sends. I know I have done this many times before, but it just didn't work. Perhaps there is some sort of corruption in this individual session.
Anyway, I then selected the first part of the track, File->Bounce to Disk, chose .wav interleaved, and, voila, it bounced the midi information to a stereo audio track.
I then did it with a mono bass track (Xpand2) and it worked like a charm. Imported both files into the session, and now I can continue tracking my other sources.
I was not aware that this was even possible. Live and learn, I guess...
-dj
iMAC 3.2GHz 6-core i7
250GB SSD (internal)
1TB SSD (external)
16GB RAM
OSX 10.14.5
PT 2019.10 (last one)
Waves Gold/RenMaxx v11
iZotope Ozone 8
Focusrite Clarett 8Pre
Nord Stage 3
Nord Lead A1
DSI Mopho X4
Old 06-05-2012, 12:33 PM
daeron80 daeron80 is offline
Default Re: Bounce Instrument Track to .wav File
Yes, it's very nice that PT adds a proprietary time stamp to the metadata of bounced files. By the way, for stereo tracks, you can bounce to dual mono and import it without having to convert. It will still make a new stereo track for it by default since the file names end in .L and .R.
If you click on the Output selector of a track, the bottom entry in the popup menu is "new track." That's probably the easiest way to bounce internally, because it creates a new track already routed.
Another way is to make a new track, name it appropriately, and assign a free bus to its Input selector. Then click on the Output selector of the track you're bouncing from and choose the "track" submenu. It will contain a list of all tracks you can bounce to including the one you just made.
David J. Finnamore
Nyquist was right.
PT 2020.9.1 Ultimate | Omni | macOS Mojave
PT 2020.9.1 | Saffire Pro 40 | Win10
Old 06-05-2012, 01:06 PM
DJKeys's Avatar
Thanks, David. I will give that a try.
1TB SSD (external)
16GB RAM
OSX 10.14.5
iZotope Ozone 8
Nord Stage 3
Nord Lead A1
DSI Mopho X4
Is it possible to bounce each track to a different wave file? sb_stefan Pro Tools 10 8 04-22-2013 07:27 PM
import midi file for virtual instrument track butchhutch Pro Tools SE and Essential (Win) 0 08-25-2012 01:31 PM
Mini Grand instrument track being distorted after bounce mrtibbs Pro Tools M-Powered (Win) 1 11-18-2009 01:05 AM
Insert Track ? Markers in a Bounce File ohok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-06-2007 04:59 PM
CAN NOT FIND INSTRUMENT TRACK UNDER FILE NEW TRACK digimike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-16-2006 04:22 PM
