Physical iLok Vs Digital iLok
Hi there.
This may seem like a simple enquiry, but here goes... I've been running my Protools 2019 via my Cloud based iLok License Manager for my studio work. However I'm looking to buy a physical iLok key, namely the 'PACE iLok V3 Smart Security Key'predominately for live shows where a venue's WIFI isn't always reliable?. I read somewhere that a physical iLok isn't necessary to boot PT, but is that just because digital iLok's exist too?. I just want some definitive clarification on this before I purchase it. I only want the physical key, so I can work offline, without having to be connected to the internet, Thanks for any insight shared. Best Pete |
Re: Physical iLok Vs Digital iLok
PT will boot from either a physical or cloud iLok; the existence of one doesn't depend on the existence of the other. I don't trust any cloud service period. Physical iLok here along with a second iLok as a spare and ZDT coverage on each. The only way I work. If you're worried about the connection between a physical iLok and the computer get a dongle buddy short extension cable to go between the iLok and computer.
Peripheral to this is that actual physical connection. iLoks are USB2 and have been known to have issues working with USB3 ports. The usual remedy is to have a powered USB hub between the devices. Also if you're on a Windows machine be sure to turn off all power saving measures to the USB ports as Windows by default (even on desktops) has the ports set to turn off after a certain amount of time. These are things that people can sometimes forget to think about. |
Hi Jack.
Thank you for your considered and detailed response. If I may ask what is... "ZDT coverage"?. I'm running my PT system on an iMac that has USB 3 Ports. So, as this is likely to cause issues, can you recommend a powered USB Hub as a go between?. Thank you for your continued insight. Much appreciated. Best Pete |
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
Also need Theft and Loss Coverage but all of that is explained in ilok.com
As to recommending a hub - that's something I can't speak to as I have all USB2 ports so don't need one as such. |
Given the nature of wifi, I will use a physical iLok 99% of the time
It is also important to check and make sure that TLC is still on for your iLok's. Reading this post...I realize that I have not been asked to renew my TLC coverage for my main iLok (it had been more than 3 months). I logged into the license manager and saw that for some unknown reason TLC had been turned off.
Sure, they won't ask you to refresh you need to schedule it yourself. Can refresh every day if you want to, but need to know when your deadline is about to arrive
Digital iLok, VS Buying a Physical iLock Key?. | Pete Morten | Pro Tools 2018 | 4 | 11-21-2018 06:06 AM |
Anyone ever done a physical repair to an ilok? | crizdee | General Discussion | 2 | 06-05-2018 02:03 PM |
iLok Cloud and other physical iLok | mik | Pro Tools 2018 | 2 | 05-04-2018 09:51 AM |
Any hints that we could ditch the physical iLok? | ryanstewartguitar | Licensing & Accounts | 9 | 09-14-2015 07:00 PM |
New iLok from Digital Village is already registered to another iLok.com account!? | Vytis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-06-2009 01:09 AM |
