Old 02-07-2010, 06:56 AM
triplex triplex is offline
Unhappy "access violation" error when catalog.ddb is close to 2GB...
Hello
I get "access violation" error when cataloging samples in DigiBase Pro and my database file (ddb) is around 2GB.
Is this expected behavior?
Thanks.
pt hd 8.0.3cs1
mac os x 10.5.8
MacPro2,1 Quad-Core Intel Xeon
12GB memory
Old 02-07-2010, 07:28 AM
Exclamation Re: "access violation" error when catalog.ddb is close to 2GB...
Originally Posted by triplex View Post
Hello
It would be if the code that is responsible for this file is not 64-bit. Only AVID can tell us for sure. 32-bit code can only address up to 2GB of space (memory, file size, etc.).
Old 02-08-2010, 08:06 AM
Default Re: "access violation" error when catalog.ddb is close to 2GB...
Thanks Chief, that makes sense.
But does the file type matters here? Because I can easily have large (over 2GB) size audio or .dmg files, for example, in a 32-bit environment on my Mac...
PT 12.8.0
Mac OS X 10.9.5
16GB RAM
Old 02-08-2010, 05:01 PM
Post Re: "access violation" error when catalog.ddb is close to 2GB...
No, file type does not matter. What matters is the application's ability to read all of the data within said file. If the underlying code for accessing a file is only 32-bit, then it will only be able to access ~2GB of data.
Old 05-18-2010, 08:16 AM
The easiest solution would be if Pro Tools was able to split its database files when cataloging...
PT 12.8.0
Mac OS X 10.9.5
16GB RAM
Found a cure for "Access Violation" error! Aargl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-09-2013 06:34 AM
assertion in "..\Mdie_TrackPlayer.cpp", line 469 / access violation/ DAE error -9400 thibault 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-22-2013 05:08 PM
If you are receiving the "Access Violation Error" read me DrFord Pro Tools TDM Systems (Mac) 0 03-30-2010 12:16 PM
Help? sudden error repeats: "access violation occurred" jojo99 Pro Tools M-Powered (Win) 5 01-26-2009 09:20 PM
"Access Violation" error - Got Help? Bozilas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-06-2001 07:08 AM
