  #41
Old 01-20-2020, 01:54 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: All lights flashing on my D-Command
Just a bit of extra info re the power supplies that might help. part numbers...
Faders board SNP-Z107
Led Board SNP-Z10B
Logic board SNP-9544
In the UK you can usually but these from Lee engineering, search google or ebay. or repaired by, Avanti power repairs.
Chris
Producer, Engineer,
www.ukmastering.com
  #42
Old 01-20-2020, 06:50 PM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by Ken Skoglund View Post
Anyways, with the new caps the PSU worked fine and I'm back in biz now, to the cost of about $10, a few 220V shocks in my arm and a lot of cussing :) Thought I share the experience if anyone wanna try it. Here is a pict with the values etc.
Nice job
Daniel
  #43
Old 01-28-2020, 11:59 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Hi all
Just got an “as-is” D-Command and it’s flashing “D-Command” across the scribble strips of faders 1&2 upon powering up. Could this be an LED power supply issue, or maybe something else? I haven’t yet tried to connect it to see if the faders still function. I’ll do that in the morning. Thanks in advance!
Ryan
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
  #44
Old 01-29-2020, 11:57 AM
Ryan Young's Avatar
Here's an interesting thing. I haven't swapped out the power supply yet, but I was plugging in my D-Command to see if it functions even without the LED displaying correctly. It thinks it's a fader pack. Could this be because it's not registering the main unit portions since they're not powered up? Could This be a "hack" to get 8 extra faders with my other main unit?
File Type: jpg Screen Shot 2020-01-29 at 11.49.07 AM.jpg (30.6 KB, 0 views)
File Type: jpg Screen Shot 2020-01-29 at 11.49.15 AM.jpg (22.8 KB, 0 views)
-Ryan Young
Additional Systems
  #45
Old 12-04-2020, 05:49 AM
Matthew Steel Matthew Steel is offline
...Here is a pict with the values etc.
[EDIT - Ken, Sorry for not thoroughly reading your post before replying. You made it clear that you removed the heat sink.]
Can anyone who has replaced the capacitors on this PSU comment on how hard it was to replace the capacitor under the heat sink?
It looks like there might be two options for accessing it:
1) Remove the entire heat sink with the two TO-220 devices still attached (it looks difficult to access the TO-220 mounting screws because of the transformer clearance).
2) Remove the inductor L5 first [next to the output connectors] and slide the cap out from under the heat sink.
Any comments of success with either of these methods?
  #46
Old 01-19-2021, 11:16 PM
neilvg neilvg is offline
Has anybody had the issue with their D-Command where it just suddenly goes haywire? All the faders and lights go nuts and the buttons stop working properly in all sections.
For example, if I press mute, it actually toggles the main monitor button. It's totally nuts. It has been doing this more and more. It will suddenly work again for some weeks and then out of the blue for almost no reason the ghosts are back in the machine. The worst part is that it messes with a bunch of stuff in pro tools if a session is open.. so I've had to stop using my D-Command.
Is this a known issue with a particular fix? The D-Command acts totally fine and as if there aren't any issues when its working properly.... When it is...
thanks!
Neil
Pro Tools 11.2.1 | HDN | OSX 10.8.5 | oMP 12-core 3.06 16gb 1333 DDR3 | 128gb Corsair Force SSD System | 256gb Asus RAIDR PCIE SSD Project | 2tb WD Samples drives
30" Cinema Display | Adam S3a and Dali MS-4 with Krell KAV-400xi amplifier | Lynx Aurora HD interface w/ Cranesong Spider via AES
  #47
Old 01-20-2021, 06:00 AM
crizdee's Avatar
thanks!
Neil
I would start with cleaning and re-seating all the connecting cables inside, as could just be a bad connection which will always be effected by temperature changes.
second, get the power supplies checked or re-built. there are places in the UK that offer this service so there must be some where you are.
After that it could be a component on one of the boards. this is difficult as tracing the fault can be hard and timely and would need an export in this field.
Have you tried resetting the unit when the fault happens?
Chris
Producer, Engineer,
www.ukmastering.com
  #48
Old 01-20-2021, 09:36 AM
I've tried just about everything, including opening the power supply panel under the monitor section and reseating cables there... its just the weirdest thing.. and suddenly it will be OK for a few weeks and then back to haywire. It seems so odd that even the buttons become mapped incorrectly. I haven't tried cleaning the cable connections though. Is there a particular product you recommend to do this?
I don't know what else to reseat - I haven't tried opening the entire board. I did buy a new PSU board a few years ago... 5 years ago maybe?
I do know the guys over at Avid here locally in Berkeley, CA. I should reach out to my personal contacts and see what they can do... I just feel that the issue may indeed take some specific troubleshooting onsite...
I've moved my DCommand off to another room for now.. its a shame its beautiful in all other regards beyond that.
  #49
Old 01-20-2021, 12:04 PM
crizdee's Avatar
The best stuff to use is deoxit caig to clean and maintain good contact.
Chris
Producer, Engineer,
www.ukmastering.com
  #50
Old 03-30-2021, 12:47 PM
denilsoncampos denilsoncampos is offline
Facing same problem. Does anyone know where can I find this PS (besides Avid)?
Mbox 3 Flashing lights drumzalicious FireWire & USB Audio Interfaces (Mac) 3 06-01-2014 02:23 AM
Flashing lights Mbox Sid0 FireWire & USB Audio Interfaces (Win) 11 04-23-2013 03:58 PM
flashing lights? stainless ICON & C|24 1 05-31-2006 02:49 PM
Flashing lights on 002, anyone else? Jak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-09-2003 09:46 PM
What's with the flashing lights? ngisedigid Pro Tools TDM Systems (Mac) 10 02-28-2002 01:06 AM
