if you have a Gigabyte EX58-UD3R motherboard please help me.
Here are my spects, after years of no errors with ptle 7.4 on a core 2 duo, I upgraded to PTLE8 and a new i7 desktop. Now I get the increase your buffer error when I do that later I get the decrease your buffer. Here is the report...
SiSoftware Sandra Computer Model : Gigabyte EX58-UD3R Workgroup : WORKGROUPS Host Name : ptcpu User : d-nizzle Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Gigabyte EX58-UD3R BIOS : Award (Phoenix) FB 05/04/2009 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.25GB DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Giga-Byte Core CPU Generic Non-Core Registers Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 6GB DDR3 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : Patriot Memory 1333EL Series 2GB DIMM DDR3 PC3-10700U DDR3-1334 (7-7-7-20 4-27-8-4) Memory Module : Patriot Memory 1333EL Series 2GB DIMM DDR3 PC3-10700U DDR3-1334 (7-7-7-20 4-27-8-4) Memory Module : Patriot Memory 1333EL Series 2GB DIMM DDR3 PC3-10700U DDR3-1334 (7-7-7-20 4-27-8-4) Video System Video Adapter : ATI Radeon HD 4350 (40 SP 600MHz, 1GB DDR3 2x400MHz, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 4350 (40 SP 600MHz, 1GB DDR3 2x400MHz, PCIe 2.00 x16) Graphics Processor Adapter : ATI Radeon HD 4350 (40SP 600MHz, 1GB 400MHz) Storage Devices WDC WD4000AAJS-00YFA0 (400GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 373GB (D:) WDC WD2500JS-22NCB1 (250GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 233GB (C:) Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) : 932GB (F:) ATAPI iHAS324 A (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 228GB (NTFS) @ WDC WD2500JS-22NCB1 (250GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) 1TB (F:) : 932GB (NTFS) @ Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) WD400G (D:) : 373GB (NTFS) @ WDC WD4000AAJS-00YFA0 (400GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Optical Drive (E:) : N/A @ ATAPI iHAS324 A (SATA150, DVD+-RW, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Giga-Byte HD Audio Controller Audio Device : PC Partner R700 Audio Device [Radeon HD 4000 Series] Serial Port(s) : 1 Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Network Services Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86
recordingguy Recording Guy's Studio & Sound www.recordingguy.com Cedar Rapids, IA |
Re: if you have a Gigabyte EX58-UD3R motherboard please help me.
Well for starters ur Video card(s) are probably some of the problem as well as it seems that all your drives are really slow if I'm reading it rite.. (8mg & 15-16mb cache drives won't cut it ESPECIALLY if u have(is that 2) 1g vid cards... I can take a stab & say that u did NOT look thru the i7 sticky before makin ur purchases...There maybe more but thatz what jumped out @me...
What PT interface are you using?
And why not post in the i7 thread were all the action is...............The whole point of threads like the i7 thread is that they become the central repository of all i7 related information is stored. Posting outside of the threads like theese dilutes the information and generally clutters up the forum. Just sayin.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Hey Scott Hey TOM
your hard drives are #1 culprit. 32mb cache drives are the way to go. 8mb cache drives are gonna KILL you. more than likely the cause of your errors.
2 - 1gb vid cards is gonna eat quite a bit of your available ram. will seriously limit what you can do and run.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
only 1 video card.
002R there is just 1 video card, not sure why it said 2. The drives have a smaller cash but I used them with ptle 7.4 with no problems and very large sessions. I get the error even with 10-12 tracks with ptle8.
That has absolutely nothing to do with PT, which is another reason we are so pointing out, or I'll say Sunburst pointed out that u should be in the actual thread where the whole discussion is about i7 & then u will understand better...
ok
Pro Tools HD 10.0.1 crash/freeze on GigaByte EX58-UD3R + W7 sp1 64bit Ultimate | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 45 | 05-25-2012 05:50 PM |
Update for Gigabyte GA-EX58-UD3R users | albee1952 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 40 | 03-26-2012 12:47 AM |
Gigabyte GA-EX58-UD3R and hd system | dccarson | Pro Tools TDM Systems (Win) | 0 | 10-30-2011 03:45 PM |
GIGABYTE GA-EX58-UD3R and HD Native + HD Omni ? | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 7 | 12-01-2010 05:10 PM |
Pro tools HD and GIGABYTE GA-EX58-UD3R | KKalampo | Pro Tools TDM Systems (Win) | 4 | 04-07-2010 11:26 PM |
