Old 05-14-2018, 12:06 PM
amiller amiller is offline
Default Having my 1st D-Command issue with Fader
I have 2 faders that are not responding to my touch about 90% of the time for volume automation. My workaround is to simply nudge the tracks over to faders that are working properly. Is this a sign that the faders are going bad or is there some other type of solution?
PT 12.7 HDX 2/Mac OS 10.10.5
2012 Mac Pro 3.46GHZ/64GB RAM
Old 05-15-2018, 06:52 AM
Default Re: Having my 1rst D-Command issue with Fader
Can't be 100% sure, but almost certainly your faders are wearing out and need to be replaced.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 05-15-2018, 07:23 AM
its2loud its2loud is offline
Go to Utility on DCommandvand cycle through the test options. fader, touch, etc. remove the caps from the fader in question and see if they respond to touch. If the do, clean the caps and put back on. If the fader motors are sticky, power cycle the unit. If none of this helps you may need to replace the faders. It’s time consuming but not impossible.
Old 05-15-2018, 07:39 PM
Default Re: Having my 1st D-Command issue with Fader
Indeed, those fader caps are conductive so they need to be clean and the surface needs a solid earth ground for everything to be happy
Old 05-16-2018, 11:37 AM
Wonderful, I will try these suggestions. 1 more hopefully quick Q. How do you safely remove the fader caps? Do they just "pop" off? I'm a little hesitant to get rough with it. I don't see a spot for an Alan wrench or some such thing. (I'll check and see of the manual says anything about that. Sorry, never done this before, Thanks!
Edit: Actually I see all the Alan wrench type screws for the fader section. Perhaps you have to remove all them?
Old 05-16-2018, 12:59 PM
Fader caps just come off. No tools required. Just pull them off.
Command 8 Fader issue. Can anyone help please? rpl16a ProControl, Control|24, Command|8 11 11-17-2015 04:50 PM
Command 8 Fader Issue howellette Digidesign Hardware & Software 3 05-24-2014 04:03 PM
D-Command ES + Fader Madule Fader Problems FedericoF ICON & C|24 11 05-24-2013 04:27 PM
FAder Issue D-Command kd_special ICON & C|24 9 07-10-2010 10:30 AM
Command 8 Fader Issue iron_aidan ProControl, Control|24, Command|8 9 12-06-2008 10:49 AM
