Old 04-12-2018, 11:00 AM
The-Edge The-Edge is offline
Default External FX Loop
OK haven't used the External FX loop on 11R and may be a newbie question even though I've been using 11R for a year. is the External FX loop only usable for live playing ? Meaning if I wanted to record in Pro Tools using my pedal board connected into the 11R FX loop would that work ? Ho would i slect or shut off internal FX and use external FX loop ? Sorry manual is not quite clear on this.
Thanks !!
Old 04-13-2018, 06:35 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: External FX Loop
Using your external effects will work fine in PT. Just disable all the internal FX using the front panel buttons and enable the FX loop using the button on the front panel. Record the 11R in PT just like you normally would using the Rig L or R inputs in PT.
Will K
System Details
Old 04-13-2018, 06:36 AM
Thanks, after looking it the manual last night some more figured this was the case. I appreciate the help
Old 04-16-2018, 09:28 PM
zedhed's Avatar
zedhed zedhed is offline
Of course you can use the External loop simultaneously with the Internal FX blocks as well if required and the Loop block can be moved around in the signal chain, just as all other blocks can.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
external midi sequencer + loop playback beatnik MIDI 1 11-22-2016 03:52 PM
Loop Sync vs external word clock in.... all HDio interfaces MixerGuy Pro Tools HDX & HD Native Systems (Mac) 13 06-01-2014 10:11 PM
Mysterious Delay in External Effects Loop Cayce Pro Tools Software (Mac) 3 07-18-2012 05:27 PM
Loop sync AND external clocking Guy McDude Pro Tools TDM Systems (Mac) 2 05-19-2012 02:50 PM
how to make an external effects loop billymc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-20-2006 10:20 AM
