Old 11-12-2008, 02:01 AM
pagan5000 pagan5000 is offline
Default Introduction and Mixer Help...
Hey guys!
I just wanted to introduce myself as well as get some advice on using Pro Tools. I am a previous Cubase user and was getting a bad taste in the back of my mouth using this piece of software which still runs excellent on my Mac G4 but I have all sorts of issues running on my PC. One of the latest problems I'm having using Cubase is that when I try to Save my project to a new folder, it crashes the whole program and when I go to look in my Cubase folder it shows me that it has copied everything from my Cubase folder into my Cubase folder! }8-0 What the hey! Anyway, I'm rambling somewhat...
So just this weekend I decided to go Pro Tools M-Powered 7.4 which I have yet to find any real problems (maybe a few things such as a slow start-up and if you're going to offer plug-ins make them so I don't have to pay EXTRA to authorize them or at give the option of a demo), and PT works seemlessly with the M-Audio 1010LT card. With Cubase, I was having to adjust the latency every so often. I don't have to do that here. In fact, I don't even remember if I had to make any adjustments to the sound card. Everything seemed to work right out of the box.
Well, is there any suggestion as to a good mixer to use with Pro-Tools. Right now, I use a Behringer MX 1604A Eurorack mixer which would be along the lines of what I'm looking for with the same type of budget cost and as well I want more inputs and more busses. Can anyone point me in the right direction. Doesn't have to have USB or Firewire (a plus but not necessary), just a good quality mixer.
Also, I want to set up my iBook in order to use PT MP 7.4. What is a good cheap M-Audio interface to use that can be used on the Apple?
Thank you in advance for any and all help.
P5
Last edited by pagan5000; 11-12-2008 at 02:02 AM. Reason: I wanted to include my signature
Old 12-02-2008, 10:18 AM
SixChurchStreet SixChurchStreet is offline
Default Re: Introduction and Mixer Help...
What exactly do you want to do with an analog mixer with Pro Tools MP?
That question will determine what I'd recommend.
I use a Tapco Mix.260fx mixer with PTMP. I use it mostly for just a master volume control for playback (completely overkill for this task alone).
But I also occasionally use the 4 onboard pres (which I like a lot actually), as they have direct outs.
On top of that, I have a CD player running into it and a Cassette deck for running tracks onto and back again to get a nasty tapey sound.
If you're looking to do some of that type of stuff, I would recommend the Tapco Mix260 (it's under $200). If you wanna step it up a bit, look at the Mackie 1202, or higher models.
And the second part of your question... I think the M-Audio JamLab is the cheapest dongle/interface you can get to run M-Powered on the go. They used to be $39.99 but they might be even cheaper if you look around. Nobody wants these things, but it'll let you run The Tools.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM El Capitan | 2011 MacBook Pro 2.0GHz 4-Core i7 8GB RAM El Capitan | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2018 | Studio One 3.5
Introduction to forum, and CPU overload, what can i buy? DjEM Pro Tools Software (Mac) 4 02-09-2013 10:31 AM
introduction jehuda Pro Tools 10 4 07-13-2012 09:56 AM
Frontier Tranzport/Introduction templejazz82 Pro Tools Software (Mac) 0 03-12-2012 12:52 PM
Arjen (Altiverb) Introduction Arjen (Audio Ease) Pro Tools TDM Systems (Win) 4 06-30-2006 02:12 PM
Newbie Introduction and Question bknight2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 01-19-2004 01:52 PM
