Old 10-11-2019, 01:31 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Maddening MIDI
There are still some very weird MIDI bugs with PT. I'm running 2019.6
I have an instrument track with MIDI notes (chord progression) that I recorded onto it. ( I think I may have stepped recorded these in). I had an8 measure progression.
I'm at the stage where I want to do some arranging of the song, so I added some measures at the start of the song and then I split up the MIDI track to isolate the 1st two measures to copy. Using ALT and L-Mouse, I dragged that clip (2 measures) over to the start and copied it 3 times to begin making the intro. Then the weirdness showed up. Clips 1&2 played just fine, but clip 3 won't play the first chord even though the notes are there! Then everything else plays fine. I deleted the 3rd clip and recopied clip 2. Same thing. Clip 2 plays fine, but first measure of clip three...silence! I deleted clips 3 & 4, and copied clips 1 & 2...same result. I even moved all the clips 4 measures earlier. Same result. Same with different VI too. Its the MIDI notes themselves that won't play. I recopied the MIDI notes. Same result. It simply refuses to play the first chord of Clip 3 no matter what! What the h...?
This isn't the first time I've run into this type of issue either, though its been a while. I also noticed when I first copied and dragged the clips that the first note of the next clip (the one after the clip I dragged) came along for the ride. I had to literally go in and re-trim the MIDI notes to fix that, even though they were already quantized!
Any thoughts?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
MIDI is Maddening! zixis9 The Drum Room 14 11-13-2013 12:17 PM
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 03:33 PM
Moving PT 10 auths to different iLok WITHOUT replacing PT 9 auths = maddening drguitar macOS 6 01-15-2012 10:01 AM
003 midi ports not there in midi studio setup? Unable to record midi now? TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-22-2009 12:06 AM
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 Michaeldante MIDI 3 03-27-2009 05:42 PM
