Old 01-26-2013, 08:59 PM
mbm1987 mbm1987 is offline
Question Odd plug-in problem VENUE
Hi folks,
It's my first time posting here.
I've come across an odd problem. One I've never encountered and possibly I'm doing something wrong.
I've installed my McDSP plug-ins (which I've done many times before) all are current v5.
VENUE software 3.0.0.315
SC-48
Problem is they're active in the system plug-in installs. Cool.
Not visible at all in the plug-in rack anywhere????
I've restarted. Disabled the plugs, reinitiated and even re-installed. Zilch.
Has anyone come across this or would they know a solution??
Obviously not always the same desks I've installed this on, with luck, in the past. SC-48 or Profile has been fine in the past.
Cheers for any help,
Regards, Matthew.
Old 01-27-2013, 06:23 AM
mariojorgeandrade mariojorgeandrade is offline
Default Re: Odd plug-in problem VENUE
Matthew.
I had the same issue when I started using ML4000, a friend had already had the same problem and McDSP's support came up with the solution:
You have to reinstall the iLok driver ( http://sw.ilok.com/DriverSetup.exe ), put your Venue in config mode, shutdown while holding the Control key, find your flash drive, double click DriverSetup.exe, agree to every message and it will work.
Good luck.
Regards,
MJ
Old 02-04-2013, 10:21 AM
prestA17 prestA17 is offline
I am having the same problem as mbm1987 except on a Venue D-Show. Mariojorgeandrade, I tried the iLok driver reinstall and I am still getting the problem. It is showing up in Options>PlugIns>Installed PlugIns but it is not showing up in the plugin rack anywhere! Any other ideas or has this worked for anyone?
Thanks,
Preston
Old 04-02-2013, 10:11 AM
Heldars Heldars is offline
Originally Posted by mariojorgeandrade View Post
Matthew.
Good luck.
Regards,
MJ
thanks for this:) It worked
EQing Vocals - Venue EQ or Plug-in EQ Tigerspill VENUE Live Sound Systems 3 10-17-2013 08:13 AM
Venue 3 and Plug-In Thumbnail Problem Kenmillerjr VENUE Live Sound Systems 9 08-08-2012 03:08 AM
VENUE stock plug-ins Jason Stygar VENUE Live Sound Systems 5 02-17-2011 08:40 AM
Suggested VENUE plug-ins mariobenipayo VENUE Live Sound Systems 10 08-09-2009 08:55 AM
Free VENUE Plug-ins v8.0 Available for Download Avid VENUE Live Sound Systems 1 03-26-2009 10:15 PM
