Old 02-22-2001, 02:28 PM
aurix1 aurix1 is offline
Default Will a Rosetta clock an 888/24?
We had this discussion before, but stil, no straight answer.
The point is: what to go for, Standahl Nanosyncs, or Rosetta?
Old 02-22-2001, 02:53 PM
jhknicks jhknicks is offline
Default Re: Will a Rosetta clock an 888/24?
bump
Old 02-22-2001, 03:19 PM
Jules Jules is offline
Yes, will it make the other 6 converters in the digi interface it is attched to - sound better - by providing them the superior Apogee clock?
Jules
Jules
London, UK
Come hang with us here!
www.gearslutz.com
Old 02-23-2001, 07:52 AM
Studio Dweller Studio Dweller is offline
I don't think the improvement would be as big as it would be with a dedicated clock like the Nanosync. The Rosetta has a wordclock out, but I don't think it outputs Superclock. Since the clock would have to be derived from the AES/EBU out of the Rosetta, it would be more prone to jitter than the 888 clocked with superclock feeding it's wordclock input.
The following is an excerpt from Bob Katz's informative article on jitter (www.digido.com):
"The AES/EBU (and S/PDIF) interface carries an embedded clock signal. The designers of the interface did not anticipate that it could cause a subtle amount of jitter due to the nature of the preamble in the AES/EBU signal. The result is a small amount of program-dependent jitter which often sounds like an intermodulation, a high-frequency edge added to the music. To minimize this effect in the listening, use a D/A converter with a high degree of internal jitter reduction. An external jitter reduction device that removes the subcode signal (containing time of day, start IDs, etc.) also helps.
The SDIF-2 (Sony Digital Interface-2) uses a separate cable for the clock signal, and thus is not susceptible to program-dependent jitter. However, the quality of the PLL used to detect an SDIF-2 wordclock is still important to low jitter. It is much easier to build a low-jitter PLL for a wordclock signal than for an AES/EBU signal."
Larry Bentley
Cellar Dweller Productions
www.cellardweller.com
[This message has been edited by Studio Dweller (edited February 23, 2001).]
Larry
PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24
Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2
Old 02-23-2001, 08:00 AM
knewbee knewbee is offline
So -- what is the best clock source? I use a Rosetta on my 888/24, which I love. Would there be a noticeable improvement from different clock sources...?
Old 02-23-2001, 08:42 AM
I doubt an external clock like the Aardsync or Nanosync would improve your A/D conversion much since you probably do most of your tracking with the Rosetta, but clocking your 888 with one would make a big improvement in your D/A. I just bought a Nanosync and hear a noticeable improvement in D/A with the 888 clocked with it. I have not done any tests yet to see how or if it improves the A/D of the 888.
Larry Bentley
Larry
Old 02-23-2001, 10:40 AM
NSS NSS is offline
Where's a good place to get the Nanosync? I'm having a bit of trouble locating one.
NSS
Old 02-23-2001, 11:37 AM
Camilo Orozco's Avatar
Camilo Orozco Camilo Orozco is offline
NSS,
Email Ken at Aaaudio@aol.com
Good prices, very nice service!
.02
Camilo
Camilo Orozco
Like us on www.facebook.com/artedigitalestudio
www.estudiodegrabacion.com.mx
Old 02-23-2001, 01:39 PM
Originally posted by Noiz2:
I have a side issue with the whole clocking discusion.
If I use superduper no jitter clock brandX to sync my whole studio every thing will sound great...now what happens when I send it out say to mix somewhere else? Does the benifit of my nonjittery studio transfer or do they also have to have my superduper... and when the mix is finished and goes to mastering -well they probably have a good clock but then it goes out to consumers and we know they have a superduper hooked up to there Radio Shack receiver...
I know we should all do what we can (I'm currentl clocking off a Black Burst scource and will move up to the nanosyncs as soon as I get convinced it will make a noticable diferance) but I am curious as to how far down stream the benifits of a great clock go.
SK
I belive that a good clock also has to do something when you go AD... or am I missing something???
Camilo Orozco
Old 02-24-2001, 12:34 AM
Noiz2 Noiz2 is offline
SK
www.scottkouesound.com
SK
Rosetta clock vs. MBox 2 Pro clock zionbrian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-15-2010 09:39 PM
192 or rosetta 800 word clock? NobodyImportant Pro Tools TDM Systems (Win) 0 05-07-2010 10:33 AM
Using Rosetta to clock my 002R gtrplyr1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-18-2004 02:43 PM
Rosetta Word Clock? Superbee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-05-2002 11:20 PM
Please Help....How can i clock my 888/24 using my rosetta...!! yu121 Tips & Tricks 8 03-27-2001 06:03 PM
