Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 04-12-2010, 02:11 AM
RossoRacer RossoRacer is offline
Default CPU overload on Mac Pro quad core
I can't believe this is actually true. Running 8.0.3 with M-Box 2 mini and it falls over every time I use it, with more than one Arturia virtual instrument! That's all. According to Activity Monitor I'm not even using more than 40% of the available CPU power. It is just about unusable, and I'm not even recording yet? What is going on?
Old 04-12-2010, 07:08 AM
flommer flommer is offline
Default Re: CPU overload on Mac Pro quad core
Read This
http://duc.digidesign.com/showthread.php?t=227746
Also This:
http://duc.digidesign.com/showthread.php?t=147797
Pay particular attention to the part about making sure your plugins are compatible
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 04-12-2010, 04:39 PM
barters81 barters81 is offline
When I started using an external drive, and pretty much followed every troubleshooting option in the guidelines given above, cpu overload hasn't happened since.
Old 04-14-2010, 05:56 AM
Digiwave Digiwave is offline
I started using an external HD and still have problems with cpu overload, to be quite honest im totally regretting upgrading my system as my old pc running xp with delta 1010lt worked perfect
CPU overload on a i7 quad - Mac OS X 10.6.8 lanstrad macOS 1 02-19-2012 11:08 PM
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-12-2009 02:24 AM
Mac Pro Quad 3.0ghz 4 core vs. Dual Quad 8 core? AllThingsMusicStudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-04-2008 08:22 AM
Single core vs. dual core vs. quad core John Peeples Tips & Tricks 9 11-07-2007 03:28 PM
overload on quad with 002????? help please!!!!! patrick1307 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 07-24-2006 08:54 AM
