Old 05-31-2009, 07:42 PM
jlcnyc jlcnyc is offline
Default Mbox 2 Pro/Rosetta 200 - external clock problems
I recently switched from a Mbox 2 (usb) to a Mbox2 Pro (firewire)
my problem - using Mbox 2 Pro w/ Apogee Rosetta 200 as external clock
confirmed that the mbox 2 pro is working - when i set the clock source to "internal" - all systems go. I even see signal passing thru the Rosetta - so this means that the spdif I/O is working - right?
But when I try to set the clock source to "external" - i get the message
"no external clock source is detected. Please check the connections...."
I never had ANY trouble with my Mbox 2(usb)/Rosetta setup ...
but I can't get the PRO (firewire) to work??????
help please
thanks
www.jeffreyleecampbell.com
Mac Pro 2.8 GHz Quad
16GB RAM
Apogee Rosetta 200/ UA LA-610
Genelec 8030A/7050b
McDSP, Waves, Sony, URS, Spectrasonics, BFD, Altiverb
Old 05-31-2009, 07:54 PM
Default Re: Mbox 2 Pro/Rosetta 200 - external clock problems
NEVERMIND - PROBLEM SOLVED
when they say check the connections - they mean it!!!!!!
one of my spdif cables had become unplugged
DUH!!!!!
all systems go
16GB RAM
Genelec 8030A/7050b
Rosetta clock vs. MBox 2 Pro clock zionbrian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-15-2010 09:39 PM
problems with external clock and mbox pro peter99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 06-05-2009 04:20 AM
Problems Bouncing to MP3 using External Clock mjake03 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-12-2009 09:34 AM
Internal vs. external clock (Digi002 and Apogee Rosetta)? Hugen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-29-2008 10:26 AM
How do I use my Rosetta as ADDA and clock w/Mbox 2 Pro? Daviskenn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-28-2007 07:58 PM
