Old 12-17-2004, 04:04 PM
gtrplyr1 gtrplyr1 is offline
Default Using Rosetta to clock my 002R
I'm having some trouble getting my 002R to accept my Apogee Rosetta as a master clock when using the optical output. I just upgraded from a 001 and was having no trouble at all when clocking through the optical outs...but now that I've installed the 002 I get a error message saying that Pro Tools is reverting back to the internal clock everytime I try the Optical out. I've even gone through this problem with Digi tech support with no luck....they think I might have a bad cable...I'm sure that's a possibility but I kind of doubt it...I'm going out to get another optical cable to try but in the meantime...any ideas ? I am running a slow computer (G4 466Mhz) with plenty of RAM ....I don't see why the speed would make any difference but .....I have been able to use the Rosetta's s/pdif (rca) output without a problem. I have tried all of the possible settings on the Rosetta and the Pro tools software...ie setting the optical out status (s/pdif or adat) ....
Thanks,
PD
Old 12-17-2004, 05:08 PM
Default Re: Using Rosetta to clock my 002R
Sorry...I should add :
Mac G4 466Mhg 768MB , OS 10.2.8 Pro Tools 6.1.2
Old 12-17-2004, 06:37 PM
How many optical cables are you using?
If just one, it needs to go from the Apogee optical out to the 002 optical IN.
Quad 2.5 G5, 4.5G RAM
Old 12-18-2004, 08:07 AM
Just the one.....Out of the Rosetta > In to the 002 .....it should work fine...I really curious if it's a software thing opposed to some sort of hardware problem...
Old 12-18-2004, 01:59 PM
Tubz Tubz is offline
Not that I have the answer for you, but I have never had a problem slaving a 002 or mbox to my RME. Tryed both as a master and slave. So I don't think it's bad software.
BR Tubz
Old 12-18-2004, 02:43 PM
Thanks for all of the ideas everyone !.....turns out it is a ....BAD CABLE !!!!!!!!! Unbelievable...
Take care,
PD
Rosetta clock vs. MBox 2 Pro clock zionbrian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-15-2010 09:39 PM
digi 002r problem, rosetta 200 word clock @ 96 kHz mrloquacious 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-23-2006 06:02 PM
rosetta clock with 888's univox1 Pro Tools TDM Systems (Mac) 4 04-12-2002 05:23 PM
Please Help....How can i clock my 888/24 using my rosetta...!! yu121 Tips & Tricks 8 03-27-2001 06:03 PM
Will a Rosetta clock an 888/24? aurix1 Tips & Tricks 21 03-05-2001 04:35 PM
