Old 06-08-2004, 05:22 PM
PedMar PedMar is offline
Default Access Virus Indigo Problem
I created a ProTools 6.1 file using four Indigo plugins, each being driven by a separate midi channel. It worked great and I saved the completed file. But when I re-opened the file, there was no sound on playback. I quickly discovered the i/o label was italicized, and Indigo no longer shows up on the midi output list. I even tried deleting and re-inserting the plugin on the insert of the corresponding audio channel.
Anyone have a suggestion as to what might be going on here?
(FYI, I'm running a 24 Mix Plus system on a system with a 3GH Intel Processor, 1GB RAM)
Steve Mark
PedMar, Inc.
Old 06-09-2004, 04:15 AM
debolish's Avatar
debolish debolish is offline
Default Re: Access Virus Indigo Problem
Not sure if this helps, but I have to reselect "Virus 1a" on the Midi track each time I open songs which use the Virus.
MacBook Pro 2.5 GHz i7 • 16 GB RAM • OS X 10.9.5 • PT 11.3
Old 06-09-2004, 10:55 AM
That's the first thing I tried. But it's not even coming up on the list of available midi outputs.
Steve Mark
PedMar, Inc.
Old 06-16-2004, 03:49 AM
Slypolk Slypolk is offline
I seem to be having the same problem.
There are no midi outputs for the indigo devices.
Whom should we contact regarding this matter.
Digi Tech Support ???
When I contact Access.De they have in the past reffered me to Digi?
Old 06-18-2004, 03:25 PM
Rammelt Rammelt is offline
I've also got this problem. Or kind of.
I can always choose the Indigo as output again.
But the problem doesn't appear every time I open a Session with Indigo's in it.
Haven't been able to see any pattern yet.
I'm also on Mix plus, 6.1 and P4 2,6. I also use FXPansion's VST2RTAS wrapper pretty much in Sessions with Indigo. How about you?
Regards,
John
John Rammelt
Producer / Composer / Post
Hajp AB
old site:
Soundfactory JPR
Old 06-18-2004, 03:55 PM
debolish's Avatar
I'm running Mix3/PT6.1/OS10.2.8 here.
Avid Access Virus Indigo? timeey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-02-2012 04:09 AM
Access Virus Indigo AAX? stargazer macOS 2 11-30-2011 03:32 AM
Access Virus Indigo James Drake Pro Tools TDM Systems (Mac) 4 06-23-2010 02:20 PM
PT 6.4.1 Mix & Access Virus..? (Red or Indigo) Citrin Pro Tools TDM Systems (Mac) 2 03-03-2009 07:00 PM
Problem with Access Virus Indigo & PT 7 stevegalante Pro Tools TDM Systems (Mac) 8 12-08-2005 01:52 AM
