Is there a way lock some parameters on tracks controlled by a VCA
I got a VCA with 6 tracks in it. And I want the VCA to control mute on/off for all 6 tracks, but I also want it to only control the volume fader for 4 of them, i.e. leave the other 2 track volumes unaffected by any VCA volume moves.
Basically lock the volume fader for two of them, but leave mute operational on all. Any obvious way to do this with a single VCA? Thx. |
Re: Is there a way lock some parameters on tracks controlled by a VCA
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Yeah that’s what I’m doing at the moment. Just wanted to see if there was a way to do it with a single VCA.
I think that goes against what a VCA is intended for. I can't even disable the volume control of a VCA's Mix group - though I don't know why anyone would need to.
The four tracks you want totally controlled should be assigned to the VCA. Then group the other tracks in a group with the VCA not following globals and only select mutes.
Mac Pro 2013 12 Core Trashcan, 64 gigs, OSX 10.14.6 PT HD Ultimate 2021.12 HDX with Focusrite Red 8pre, Rednet 2, R1, Dock + S3. |
Yes but that means creating 2 VCA's. Which is what I'm already doing. Just wanted to see if I could get away with just 1 VCA to save a little space in my layouts.
Can Midi Tracks be volume/mute controlled by a VCA Master? | dumbeat | Pro Tools 10 | 1 | 04-30-2015 04:34 PM |
changing plugin parameters on track/bus affects unrelated tracks | julius.ce | macOS | 27 | 03-22-2014 03:54 PM |
2 instrument tracks each controlled by different MIDI input/instrument | Midimax | Pro Tools M-Powered (Win) | 0 | 03-20-2012 03:10 PM |
Lock Tracks? | blastula | Pro Tools TDM Systems (Mac) | 8 | 07-08-2007 08:57 PM |
USING SC IN A MAC, CONTROLLED FROM ATARI? | pongo7 | Digidesign Hardware & Software | 1 | 11-01-2000 08:33 AM |
