Old 09-18-2020, 12:16 AM
BigBadBill BigBadBill is offline
Default Is there a way lock some parameters on tracks controlled by a VCA
I got a VCA with 6 tracks in it. And I want the VCA to control mute on/off for all 6 tracks, but I also want it to only control the volume fader for 4 of them, i.e. leave the other 2 track volumes unaffected by any VCA volume moves.
Basically lock the volume fader for two of them, but leave mute operational on all.
Any obvious way to do this with a single VCA? Thx.
Old 09-18-2020, 01:00 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Is there a way lock some parameters on tracks controlled by a VCA
I don't think so but you can do it with easily 2 VCAs.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 09-18-2020, 03:11 AM
Yeah that’s what I’m doing at the moment. Just wanted to see if there was a way to do it with a single VCA.
Old 09-18-2020, 03:31 PM
cwsand's Avatar
I think that goes against what a VCA is intended for. I can't even disable the volume control of a VCA's Mix group - though I don't know why anyone would need to.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 09-21-2020, 07:31 AM
MrDibS MrDibS is offline
The four tracks you want totally controlled should be assigned to the VCA. Then group the other tracks in a group with the VCA not following globals and only select mutes.
Mac Pro 2013 12 Core Trashcan, 64 gigs, OSX 10.14.6
PT HD Ultimate 2021.12 HDX with Focusrite Red 8pre, Rednet 2, R1, Dock + S3.
Old 09-24-2020, 10:37 AM
Yes but that means creating 2 VCA's. Which is what I'm already doing. Just wanted to see if I could get away with just 1 VCA to save a little space in my layouts.
Can Midi Tracks be volume/mute controlled by a VCA Master? dumbeat Pro Tools 10 1 04-30-2015 04:34 PM
changing plugin parameters on track/bus affects unrelated tracks julius.ce macOS 27 03-22-2014 03:54 PM
2 instrument tracks each controlled by different MIDI input/instrument Midimax Pro Tools M-Powered (Win) 0 03-20-2012 03:10 PM
Lock Tracks? blastula Pro Tools TDM Systems (Mac) 8 07-08-2007 08:57 PM
USING SC IN A MAC, CONTROLLED FROM ATARI? pongo7 Digidesign Hardware & Software 1 11-01-2000 08:33 AM
