#411
Re: Dark Theme in Pro Tools 2020.11
Open the Applications folder on your Mac. You next right click on the PT program icon in the Applications folder and select 'show package contents'. Open the 'contents' folder. Next open the 'resources' folder. Next open the 'skins' folder. You should see a folder named 'dark'. Right click on that folder and do a 'get info'. Change the permissions of system and admin to 'read & write'. Close that window. Then open the 'dark' folder. To keep the existing dark mode file drag it to your desktop and save it to a good place. Then drag in the dark mode file you created in text edit. Should be good to go after a reboot. Do all this with PT closed. |
#412
#413
musicman691 that's great news about your sister!! I am finally finishing up some projects and thinking about doing this mod. I've been using dark mode for a while and find it mostly ok, with the big exception of the Groups pane and the [lack of] difference between groups suspended or not. That said, I'm sure I'll like your mods even better. A couple questions. Inside the path you specified: Pro Tools.app>Contents>Resources>Skins>Dark there is no "dark mode.txt" file, only a PTColors.txt file, as well as a couple of other files with .idb extensions. Second, TextEdit on my system (10.14.6) only lets me save as .rtf, not .txt. Can I just change the extension to .txt in finder? Thanks!!
Scott Gatteño |
#414
It is indeed great news to hear about Marie (sis). She's had way too many surgeries in her 63 years on this third rock from the sun and I am glad she was able to catch a break. If you want drop me an email using [email protected] with a regular email address and I'll send you the file I'm currently working with. It might be easier than trying to piece together the two forum posts. |
#415
Amen! Continuing to pray for her quick recovery from the surgery.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.4 running Protools 2024.3 Mac Studio M1Max - 64GB MacOS 14.3.1 running Protools 2024.3 |
#416
I really like pro tools, but I don't like the dark mode as it affects my eyes directly. I turned off instantly.
Software Programming is all about managing complexity: the complexity of the problem laid upon the complexity of the machine. But in the end, it all comes down to 0 and 1. I write about Software Development on my blogs. |
#417
Are you on Mac or Windows? If Mac grab the modified dark mode file I posted in this thread. If Windows - no help there. I don't know that anyone here has done a modified file for Windows users.
#418
Let us know how it goes. There are a couple of different modifications being used by people here and elsewhere, each employing varying color options. I've settled into a custom dark mode that handles (almost) every issue I had with the default dark mode, and there were plenty of problems.
#419
#420
FWIW I tried the latest edit to Dark Mode, which I really like BTW, but it messes up my Slate Raven setup. Just so you know. I have no idea why that would be... Oh well, the regular DM is still better than Classic IMNSHO.
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
"Dark" theme improvements in 2021.3 | midnightrambler | Pro Tools | 19 | 04-04-2021 05:15 AM |
How to change Pro Tools 12 to a Dark theme/skin | Defier | Pro Tools 12 | 7 | 03-26-2016 05:22 PM |
Pro Tools 8 theme for Reaper? | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-09-2010 07:51 AM |
Pro tools theme song....! | roijin | Pro Tools TDM Systems (Mac) | 2 | 11-27-2001 07:15 AM |
