Re: Pro Tools Carbon Laptop Fan Noise
So just another update for everyone... Yes I have checked and my laptop is compatible. I'm using a maxed out 2019 16" MacBook Pro and all the software is compatible with what Avid is looking for.
After many tests and eliminating certain things, there are 2 things sticking out... Like I originally said, in the activity monitor coreaudiod has (not responding) next to it. Also, it triples in the CPU usage once I plug in the Carbon. I can plug in an Apollo or just use the built in sound card and it stays down. Just by plugging in the Carbon it goes up to around 15%. Even when I have my sound set to the internal speakers. Again, just by plugging in the Carbon, the coreaudiod will change to "not responding" and triple in CPU usage. The other thing I've noticed now is that once you plug the Carbon in the kernel_task goes up really high. I know that has to do with the fan. The question is why is the Carbon making it go up so much. Right when you plug in the Carbon it goes up to 30% and the fan on my laptop starts running. This is what I would guess is the real culprit. The problem is there is no way for me to fix that. I'm mainly wondering is this something Avid will fix with some sort of update and if that's even possible. As good as this interface sounds, the loudness of my laptop fans running would make me return it and go back to Apollo. Obviously, it's brand new and will take a little bit to get dialed in...which I'm good with that. I would just hate it if this is something that won't change even with updates. Thanks! Chris |
Also, I decided to run a CPU temp check and see if it actually went up and it did. Without Carbon plugged in my CPU avg was 125 degrees F. After I plugged it in in would average 180 degrees F and the fans would start. Note, this is with nothing else running or even plugged into my laptop. I'm currently updating Pro Tools on a different laptop to see if the same problem occurs.
I had written another reply on here, but it's not showing up.
Wanted to add another problem with this... now I can't even change my I/O. It keeps telling me there is a new output that isn't assigned yet...which isn't true. Which now means I can't edit the I/O at all. I can't even set it back to default because it keeps giving that message and won't let me hit okay. This is starting to feel like they released this before it was ready. At least for me anyway. |
PT Ultimate I/O Problem
I have the new Carbon hooked up and the thing sounds incredible. I've run into a couple problems. One is it causes your computer processor to immediately heat up and starts running the computer fans. I'm hoping they will update and fix that.
My other problem has to do with the I/O. I opened up the I/O settings in PT and as I went to hit okay and close it I kept getting this message: “You haven’t assigned outputs for a new output path. Please assign outputs to it, or delete the path.” The problem is there aren't any new output paths. I've tried deleting all paths and hitting default on each tab, but that doesn't work. For some reason it's just hung up somehow. I also tried starting a new session and using a new stereo template, but it still doesn't work. The problem is now I can't make any changes to the I/O at all. Rename something...remove things I don't want to see in PT...etc.. Is there any way to do some sort of reset to the I/O other than the delete paths then hit default option? If my option is to reinstall PT will I have to backup all my presets somewhere? Thanks for the help! Chris |
Re: PT Ultimate I/O Problem
The presets are located in Documents/Pro Tools - you may not have to back them up if you reinstall Pro Tools, but it's always a good idea to!
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Yes, I've hit default on each Tab. Nothing works. I wish there was just a way for me to erase whatever PT has of the Carbon and start over. Between it heating up my processor and now this I/O, I currently have a $4000 unusable piece of gear. I had to plug my Apollo back in just to get some work done.
I appreciate any help on here! Thanks! Chris |
Wish I could help. I see/hear a lot of these problems popping up. Avid better start properly testing their stuff before releasing it to public.
Might be a long shot but you could try deleting the .pio files from the preferences folder?
Just in case you don't know where they are: https://www.sweetwater.com/sweetcare...s-preferences/ |
Chris, do you have a case logged with support yet? If so, please let me know the case number.
Of not, please log one and let me know what it is. Thanks... mark
Mark Corbin Avid Sr Principal Product Manager Professional Audio Systems For immediate assistance: Pro Tools & Eucon Surfaces - +1 888-456-3444 Venue Support - +1 978-275-2557 Find out how to create, manage, and edit cases online now HERE It's fast, easy, and effective! |
Pro Tools | Carbon | Avid | Technical Alerts | 0 | 11-12-2020 03:14 PM |
Audio Recording Noise Test on a new laptop.How do I reduce fan/system noise? | PeterGreen | Pro Tools 10 | 24 | 01-23-2013 06:38 AM |
Static Noise with Pro Tools LE and laptop | jallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-17-2007 10:43 PM |
