Old 05-04-2001, 04:12 PM
Montxo Montxo is offline
Default Control PT recording features via MIDI from an extenal MIDI device
Hi All,
I would like to known if there is any way to control recording functions (like REC, put in record enables a track, STOP, etc) with MIDI messages from a external MIDI device.
Thanks,
Montxo
Old 05-04-2001, 05:14 PM
doc22 doc22 is offline
Default Re: Control PT recording features via MIDI from an extenal MIDI device
Montzo,
There are a number of control surfaces that work. Try looking in the 3rd Party Compatible section of the Digi website.
I use a JL Cooper CS2-10. For me it's especially useful controlling PT from my sound booth.
Hope this helps,
Dave - doc22
Old 05-05-2001, 05:37 AM
jbr jbr is offline
Does the CS2-10 control MIDI tracks, Aux tracks and Master as well as Audio tracks?
Old 05-05-2001, 08:05 AM
jbr,
The CS controls the first 8 tracks of faders. It doesn't matter if they're Aux, Master, MIDI, recorded tracks, etc. You can also control pan, mute, record, solo, and transport. There are other controls, but these are the ones I use most often remotely. You have to arm the record of each track manually with the mouse and there is no automation. It works like the Peavey control surface, but I had better control with this one, so that's what I use. It's very reasonably priced: around $300. I bought it so long ago, I don't remember. I can see my computer screen through a window in the booth. This way I can keep the noisefloor low when I'm recording alone.
Hope this helps.
Dave - doc22
[This message has been edited by doc22 (edited May 05, 2001).]
Recording from a VST Instument without MIDI input device burcu Windows 4 07-21-2012 10:33 AM
Midi problem - no INPUT DEVICE option in MIDI menu tam103 MIDI 2 01-05-2007 08:01 AM
Can't control an external midi device... Siberian MIDI 0 03-07-2005 08:57 PM
Using Midi to control external device? sheeptuf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-10-2004 06:24 AM
Cant see dig001 as midi device in XP control panel ruben74 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-02-2003 11:11 PM
