Old 12-09-2008, 03:23 PM
Reesho Reesho is offline
Question Remove a Greyed-Out Device in Midi Setup?
If a midi device is greyed-out and is not editable, how can it be removed from the midi-setup? (the "remove device" button is also greyed-out of course)
While I'm at it I may as well ask how do you delete a midi-set up configuration?
Mac Pro 2x2.8 Ghz Dual Quad-Core Intel Xeon
14 GB Ram
OSX 10.6.8
PTLE 8.0.5
Digi 002R
Midi Controller =M-Audio Axiom 49/USB2
Old 12-09-2008, 03:54 PM
Gothboy's Avatar
Gothboy Gothboy is offline
Default Re: Remove a Greyed-Out Device in Midi Setup?
If it's greyed out it means that you need to select an instrument and it's midi channel. If you want to get rid of it just either hide, make inactive or delete the track.
If you mean hardware you have to go into midi studio and edit in there.
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core
16 GB RAM
Mountain Lion 10.8.5/El Capitan 10.11
Focusrite Saffire Pro 40
Ableton Live 9/Presonus Studio 3
I no longer use Pro Tools and just as happy!
Old 12-09-2008, 05:12 PM
Default Re: Remove a Configuration in Midi Setup!
The device is greyed-out in MIDI Studio, which is where I was trying to get rid of it. There are no tracks connected with the device.
I found a work-around for deleting a configuration anyway. It seems PT won't let you remove a configuration unless there's another config in the list. I created a new config then PT allowed me to choose the old one and delete it. This way I was able to start over but with the device in question still not removed but only refreshed. I can remove the device if I unplug it from PT and then select it's greyed-out icon and click delete, but when I plug it in again it returnes to MIDI Setup and remains un-editable.
14 GB Ram
OSX 10.6.8
PTLE 8.0.5
Digi 002R
Old 12-10-2008, 11:52 AM
DigiTechSupt's Avatar
Which device is this, exactly?
Avid Audio Tech Support
Support FAQ
Old 10-14-2016, 12:58 PM
davemartone's Avatar
davemartone davemartone is offline
Did this ever get solved?
Audio MIDI setup says DIGI 002 midi device is offline oliarnalds MIDI 17 10-23-2016 10:13 PM
Digi MIDI i/o Duplicated and greyed in Audio/Midi setup xxicjoy MIDI 69 08-02-2013 08:40 PM
midi device setup with protools hd and mac robplato MIDI 1 07-29-2012 01:46 PM
USB MIDI device connection - Mac Audio MIDI Setup jongilbertson MIDI 2 06-11-2008 10:13 PM
Midi device setup questions rgriff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-10-2004 08:27 AM
