Re: Just starting out...
What about using the Profire 2626 instead of the Motu? its M-audio(avid) so it should be compatible???
Does anyone know of another pre amp that is compatible with it then??? I need atleast 8 pres... |
Just be aware that you will need a copy of Pro Tools M-Powered.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Wont it work with LE?
So basically i cant add any 8 piece pre amps to the LE software or any of the Mbox's???
#16
Only to the 003.
#17
And don't get too caught up on LE. You can do just fine with M-powered. It's not nessecarily a downgrade from LE. M-powered Essentials is and is probably a waste of time, but the full M-power Pro Tools can usually get you in for cheaper than LE. That being said you can get an 003 on ebay for around $850, with a copy of protools 8.
2.66GHz Quad-Core Intel Xeon 6 GB SDRAM 3 1 TB WD Caviar Black Hard Drives Eleven Rack, Axiom 61 |
#18
Unless you need the DV Toolkit or Complete Production Toolkit... M-Powered is pretty well exactly the same as LE.
#19
Yeah, I almost said "they are the same except..." and then I couldn't come up with anything except Low Latency Monitoring.
2.66GHz Quad-Core Intel Xeon 6 GB SDRAM 3 1 TB WD Caviar Black Hard Drives Eleven Rack, Axiom 61 Last edited by mhelm01; 08-23-2010 at 11:51 AM. Reason: punctuation |
#20
Man, I had all but forgotten about LLM. It's a completely unnecessary feature if you have a half-decent computer, these days. I haven't used it in around a year now. Much nicer to just drop your buffer to 32 or 64 and even be able to toss a comp or verb on the track. :)
starting out | shokan | Windows | 1 | 09-24-2012 09:21 PM |
Delay between PT starting and BFD starting | Baritonealone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-01-2008 03:58 PM |
PT not starting. | Wolfgang Eller | Pro Tools TDM Systems (Mac) | 3 | 12-19-2007 07:36 AM |
Just starting | Kaje | Pro Tools TDM Systems (Win) | 1 | 12-28-2005 11:07 AM |
Starting Over...Please help! | The Mighty Burner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-02-2002 02:05 PM |
