Old 03-16-2019, 07:57 AM
PatJo PatJo is offline
Default XPand2 Presets
I'm using Protools First 2018.7.0 on a Windows 7 Dell laptop. The software was bundles with a Focusrite Scarlett 6i6.
The problem I have is that none of the presets for XPand2 are present in the drop down list. Does anyone know how to get them installed?
Thanks.
Old 03-16-2019, 08:05 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: XPand2 Presets
Hi !
Do you have the lastest version installed from Avid link app ?
- Jesus Alvarado -
Keep the volume UP !
Old 03-16-2019, 08:14 AM
How can I check that?
Thanks.
Old 03-16-2019, 08:15 AM
ChuckS ChuckS is offline
Search on Xpand. There are several topics about the same issue.
PT 2019.5 DP 10.01 VEP 7.x Komplete Audio6 HP Envy 8G i7 Quad Laptop Win10 (x64 1903)
PT 2019.5 DP 10.01 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6 (end of the OS road for the 2011 Mini)
Old 03-16-2019, 08:17 AM
jeam25's Avatar
Yes there can be a few reasons but commonly the Xpand is not seeing the .big file that contains the presets .
You can run the Avid link app and see there if you have an update available .
- Jesus Alvarado -
Old 03-16-2019, 08:27 AM
If Xpand doesn't see the .big file on startup, it presents a locate dialog. The presets offered at the top of the plug window are stored in the Documents/Pro Tools/Plug-In Settings folder.
Old 03-16-2019, 11:18 AM
Ok, so what should I actually do?
Old 03-16-2019, 11:36 AM
OK, so how do I get the presets into my setup?
Old 03-16-2019, 02:58 PM
jeam25's Avatar
Hi when you open a new xpand instance , it is displaying a screen asking for the libraries location ?
- Jesus Alvarado -
Old 03-17-2019, 02:34 AM
No. There are no errors. Everything is working perfectly but the the presets are just missing.
I loaded up one of the templates (rock) and went into the drum track and saved that preset to disk. Then I was able to load that one up in my own track which gave me one preset.
Is there a set of files somewhere that I can get that will give me all the presets? This is just broken.
XPand2! and Nexus 2 presets chrisdee Tips & Tricks 3 01-12-2016 04:05 PM
which presets in Xpand2? Suke AAX Plug-ins 2 09-03-2013 02:27 PM
Scrolling Through Presets in Xpand2 goat1927 Pro Tools M-Powered (Mac) 2 07-10-2012 11:06 PM
XPAND2 missing my patches and presets iamkimosabi Virtual Instruments 1 06-07-2012 11:34 PM
Xpand2 will not play defualt presets sgaree Virtual Instruments 0 10-08-2010 04:06 PM
