Old 03-11-2019, 04:35 PM
Lue Lue is offline
Default Importing Audio and Sample Rates
Hello, I'd like to import a .wav file into pro tools but I have an issue :)
Pro tools insists on changing the sample rate/speed/pitch of the audio when I import.
Is there a way to import audio without Pro Tools changing the speed regardless of what sample rate is setup?
Thank you for your time,
Lue
Old 03-11-2019, 07:03 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Importing Audio and Sample Rates
No. The sample rate is set for a session when it is created and is an option depending on your interface of anything up to 192. Since importing a file does not change the actual sample rate of the original file but converts and creates a new audio file there is really no reason not to do so.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.5 Native through A&H Qu-32
Old 03-11-2019, 11:05 PM
Top Jimmy's Avatar
One of two things is causing this. Either A) the source file's sample rate is misidentified in the file header, or B) the session you're importing to is running on a mis-matched sample clock.
You can actually choose to not apply SRC or to even manually force source and target sample rates via the import audio window.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Acoustica Audio Aqua - Sample Rates adam79 AAX Plug-ins 2 08-03-2018 12:31 PM
Pro Tools 11.3.1 crashes when importing audio from different sample rates feliponk Pro Tools 11 8 03-24-2015 07:01 AM
CHANGING SAMPLE RATES ON EXISTING AUDIO FILES John calvert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2006 07:16 AM
Comparing Bit-rates, Sample-rates, and convertors - Telling the difference? stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-05-2003 08:36 AM
mix audio with different sample rates usinare Pro Tools TDM Systems (Mac) 1 03-26-2002 08:46 AM
