Virtual Instruments Not showing up in PT10
Hey everyone. I'm trying my hardest not to throw my computer!
I have all my plug-ins installed, and everything works EXCEPT for any of the virtual instruments. I've tried everything I can think of. Re-installing, multiple times, changing what drive I install everything to. I have even copied and pasted the plug in files to multiple folders to see if it pops up, and NOTHING! Xpand2! Vacuum, boom, mini grand, and a few others which I'm sure you're familiar with, will NOT show up in the instrument plug ins. Can anyone help me? I am at a total loss of what to do... Thanks -J |
Re: Virtual Instruments Not showing up in PT10
Hi
Have you installed the separate instrument installer which is called version 10.3 for PT10? This file should be 2.6-2.7GB and needs to be installed after PT10.. Also we need more info on your setup. Read this before posting back please http://duc.avid.com/showthread.php?t=300050 Be Well Chris
Thanks! That read through was insightful.
Here are my specs Windows 7 64bit. Custom build 8GBram Intelcore i5 3.00Ghz Eleven Rack interface USB Protools 10 Presonus 44vsl I looked at the installer you suggested. But I am running windows, and I already have the most updated windows installer, which seems to be 10.0. I tried finding multiple forums finding the problem I'm having, and no one seems to be having the same issue. This is all very confusing... Any more thoughts? |
Hi
The latest version for both Windows and Mac is 10.3 Found here http://secure.digidesign.com/service...rticleId=43572 Do all the preferences deleting aswell as Volumes and DAE folder. http://www.sweetwater.com/sweetcare/...ces-databases/ Follow this here and domevery step. Then reinstall the latest installer I posted. Try these steps and post back Good Luck Christopher
Thank you SO SO SO much!!!!
I had all the updates and I made sure of that. I went through the deletion process. Deleting 'Databases made' PT10 not work, so I put that folder back, but deleting the preferences folder changed it. My plug-ins work! Seriously, thank you so much! Happy New Year Christopher! -Jared |
Arabic Virtual Instruments within PT10, help please | Eihab | Pro Tools 10 | 14 | 03-17-2013 11:32 AM |
Sibelius 6.1 is not showing in instruments | pipeorgan | Pro Tools M-Powered (Win) | 2 | 09-04-2012 02:40 PM |
Installing PT10 Virtual Instruments | kyoung91 | Pro Tools 10 | 2 | 02-21-2012 12:01 PM |
Avid Virtual Instruments crash on PT10 | Kaze | Virtual Instruments | 6 | 02-13-2012 04:45 PM |
Sibelius 6 not showing in instruments | Choral14 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 07-16-2010 05:33 PM |
