Old 12-18-2005, 10:25 PM
STSCRUSHER STSCRUSHER is offline
Default Sandra report
How much is needed from this report to trouble shoot? I'm having problems with buffer increase/decrease errors. I've done everything recomended thus far. This is a reformat and clean installation. Thank you.
Processor >
Model: AMD Athlon(tm) XP 2200+
Speed: 1.80GHz
Model Number: 2200 (estimated)
Performance Rating: PR2603 (estimated)
Cores per Processor: 1 Unit(s)
Threads per Core: 1 Unit(s)
Internal Data Cache: 64kB Synchronous, Write-Back, 2-way set, 64
byte line size
L2 On-board Cache: 256kB ECC Synchronous, Write-Back, 16-way set,
64 byte line size
< Mainboard >
Bus(es): ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus
MP Support: 1 Processor(s)
MP APIC: Yes
System BIOS: Phoenix Technologies, LTD 6.00 PG
System: eMachines, Inc. L7VMM2
Mainboard: KM266-8235
Total Memory: 992MB DDR-SDRAM
< Chipset 1 >
Model: Elitegroup Computer Sys VT8375 ProSavageDDR
PM266/KM266 CPU to PCI Bridge
Front Side Bus Speed: 2x 133MHz (266MHz data rate)
Total Memory: 1GB DDR-SDRAM
Shared Memory: 32MB
Memory Bus Speed: 2x 133MHz (266MHz data rate)
< Video System >
Monitor/Panel: Plug and Play Monitor
Adapter: S3 Graphics ProSavageDDR
< Physical Storage Devices >
Removable Drive: Floppy disk drive
Hard Disk: WDC WD1000BB-00CAA1 (93GB)
Hard Disk: LaCie Group SA LaCie 1394 Disk drive LUN 0
IEEE 1394 SBP2 Device
Hard Disk: SEAGATE ST3250823A USB Device
CD-ROM/DVD: SAMSUNG CD-R/RW SW-240B (CD 199X Rd, 40X Wr)
CD-ROM/DVD: SAMSUNG DVD-ROM SD-616T (CD 48X Rd) (DVD 6X
Rd)
< Logical Storage Devices >
1.44MB 3.5" (A:): N/A
Hard Disk (C:): 93GB (86GB, 93% Free Space) (NTFS)
CD-ROM/DVD (D:): N/A
Wusb54gs (E:): 39MB (CDFS)
New volume (G:): 112GB (37GB, 33% Free Space) (NTFS)
< Peripherals >
Serial/Parallel Port(s): 2 COM / 1 LPT
USB Controller/Hub: VIA Rev 5 or later USB Universal Host
Controller
Controller
Controller
USB Controller/Hub: VIA USB 2.0 Enhanced Host Controller
USB Controller/Hub: USB Root Hub
USB Controller/Hub: USB 2.0 Root Hub
USB Controller/Hub: USB Composite Device
USB Controller/Hub: USB Mass Storage Device
FireWire/1394 Controller/Hub: VIA OHCI Compliant IEEE 1394 Host Controller
Keyboard: HID Keyboard Device
Mouse: PS/2 Compatible Mouse
Human Interface: HID-compliant device
Human Interface: HID-compliant consumer control device
Human Interface: USB Human Interface Device
< MultiMedia Device(s) >
Device: Avance AC'97 Audio for VIA (R) Audio
Controller
< Communication Device(s) >
Device: 56Kbps Internal Modem
< Power Management >
AC Line Status: On-Line
< Operating System(s) >
Windows System: Microsoft Windows XP/2002 Home (Win32 x86)
5.01.2600
< Network Services >
Adapter: Realtek RTL8139 Family PCI Fast Ethernet NIC
< Performance Tips >
Warning 100: Large memory sizes should be made of
Registered/Buffered memory.
Tip 2546: Large memory modules should be ECC/Parity.
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
<<< Mainboard Information >>>
< System >
Manufacturer: eMachines, Inc.
Model: L7VMM2
< Mainboard >
Manufacturer: Elitegroup (ECS)
MPS Version: 1.40
Model: KM266-8235
System BIOS: 09/03/2002-KM266-8235-6A6LVE1BC-00
Chipset: VIA KT266/A, KT333/A
< System Memory Controller >
Error Correction Capability: None
Number of Memory Slots: 2
Maximum Installable Memory: 2GB
Bank0/1 - A0: DIMM 512MB
Bank2/3 - A1: DIMM 512MB
< Chipset 1 >
Maximum FSB Speed / Max Memory:2x 133MHz / 2x 133MHz
Width: 64-bit
IO Queue Depth: 4 request(s)
< Chipset 1 Hub Interface >
Type: V-Link
Width: 8-bit
Full Duplex: Yes
Multiplier: 2/1x
Speed: 4x 66MHz (264MHz data rate)
IO Queue Depth: 9 request(s)
< Logical/Chipset 1 Memory Banks >
Bank 0: 256MB DDR-SDRAM 2.5-3-3-7 2CMD
Bank 1: 256MB DDR-SDRAM 2.5-3-3-7 2CMD
Bank 2: 256MB DDR-SDRAM 2.5-3-3-7 2CMD
Bank 3: 256MB DDR-SDRAM 2.5-3-3-7 2CMD
Shared Memory: 32MB
Bank Interleave: 4-way
Multiplier: 1/1x
Width: 64-bit
Power Save Mode: No
Fixed Hole Present: No
< APIC 1 >
Version: 0.03
Speed: 16MHz
Multiplier: 1/2x
Maximum Interrupts: 24
IRQ Handler Engaged: Yes
Enhanced Support: Yes
< Memory Module 1 >
Manufacturer: Samsung
Model: M3 68L6423DTL-CB0
Serial Number: 35510E01
Type: 512MB DDR-SDRAM
Technology: 16x(32Mx8)
Speed: PC2100U 2.5-3-3-6
Date of Manufacture: Tuesday, January 14, 2003
Set Timing @ 133MHz: 2.5-3-3-6
Set Timing @ 100MHz: 2.0-2-2-5
< Memory Module 2 >
Manufacturer: Kingston
Model: K
Serial Number: 51302474
Speed: PC2700U 2.5-3-3-7
Date of Manufacture: Saturday, February 19, 2005
Set Timing @ 167MHz: 2.5-3-3-7
Set Timing @ 133MHz: 2.0-2-2-6
< Environment Monitor 1 >
Model: ITE IT8705F LPC
Version: 2.00
Mainboard Specific Support: No
< Temperature Sensor(s) >
Board Temperature: 54.0°C / 129.2°F
CPU Temperature: 40.0°C / 104.0°F
< Cooling Device(s) >
Auto Fan Speed Control: No
Chassis Fan Speed: 4821rpm
< Voltage Sensor(s) >
CPU Voltage: 1.65V
Aux Voltage: 2.50V
+3.3V Voltage: 3.30V
+5V Voltage: 4.76V
+12V Voltage: 12.42V
Standby Voltage: 6.85V
Battery Voltage: 3.39V
< AGP Bus(es) on Hub 1 >
Version: 2.00
Multiplier: 1/2x
Fast-Writes Enabled: No
Side Band Enabled: No
Side Band Support: Yes
Aperture Size: 64MB
< PCI Bus(es) on Hub 1 >
Version: 2.10
Number of Bridges: 1
PCI Bus 0: PCI (33MHz)
Multiplier: 1/4x
< LPC Hub Controller 1 >
Model: Elitegroup Computer Sys VT8235 PCI to ISA
Bridge
ACPI Power Management Enabled: Yes
Delayed Transaction Supported: Yes
Delayed Transaction Enabled: No
Multiplier: 1/4x
Speed: 8MHz
DMA Multiplier: 1/2x
DMA Speed: 4MHz
< USB Controller 1 >
Model: Elitegroup Computer Sys VT82xxxxx UHCI USB
1.1 Controller (All VIA Chipsets)
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
Supported Speed(s): Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled: No
< USB Controller 2 >
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 3 >
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 4 >
Model: Elitegroup Computer Sys VT6202/12 USB 2.0
Version: 2.00
Specification: 1.00
Interface: EHCI
Channels: 6
Companion Controllers: 3
Supported Speed(s): Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support: 32-bit
< FireWire/1394 Controller 1 >
Model: VIA Technologies Inc VT6306 VIA Fire II IEEE-
1394 OHCI Link Layer Controller
Version: 1.00
Interface: OHCI
Enhanced Support: No
Speed: 400MHz
< System SMBus Controller 1 >
Model: VIA VT823x SMBus
Advanced TCO Mode Enabled: No
Slave Device Enabled: No
PEC Support: No
Speed: 16kHz
< Expansion Slot(s) >
PCI0 (1h): PCI 32-bit +5V PME Full-Length Used (VIA
Technologies Inc VT8633 Apollo Pro 266 CPU to
AGP Controller)
PCI1 (2h): PCI 32-bit +5V PME Full-Length Available
PCI2 (3h): PCI 32-bit +5V PME Full-Length Available
PCI3 (4h): PCI 32-bit +5V PME Full-Length Used
AGP (8h): AGP 32-bit +5V Full-Length Available
(Elitegroup Computer Sys 86C420 ProSavage
DDR)
< Port Connector >
PRIMARY IDE: None - ATA / None
SECONDARY IDE: None - ATA / None
FDD: 8251 FIFO - Floppy Disk / None
COM1: Serial Port 16450 - 9 Pin Dual Inline / DB-9
pin male
COM2: Serial Port 16450 - 9 Pin Dual Inline / DB-9
pin male
LPT1: Parallel Port ECP/EPP - DB-25 pin female / DB-
25 pin female
Keyboard: Keyboard - PS/2 / PS/2
PS/2 Mouse: Mouse - PS/2 / PS/2
USB: USB - None / None
Notice 224: SMBIOS/DMI information may be inaccurate.
Warning 2507: Mainboard has too few memory slots. Upgrading
the memory may be difficult or expensive.
Warning 2508: All memory slots are full. Upgrading the
Warning 2544: System/Video shared memory greatly reduces
performance. Use external video card.
Warning 2518: Mainboard temperature is too high.
tip.
<<< CPU & BIOS Information >>>
<< CPU 1 [Processor 0, Core 0, Thread 0] >>
< Processor >
Speed: 1.80GHz
Package: Socket A PGA
Multiplier: 27/2x
Generation: G7
Name: Duron M8 & Athlon MP/XP & Sempron
(Thoroughbred) 130nm 1.5-2.5GHz+ 1.5-1.65V
Revision/Stepping: 8 / 0 (0)
Stepping Mask: A0
Core Voltage Rating: 1.650V
Maximum Physical / Virtual Add:34-bit / 32-bit
Native Page Size: 4kB
< Co-Processor (FPU) >
Type: Built-in
< Processor Cache(s) >
byte line size
Internal Instruction Cache: 64kB Synchronous, Write-Back, 2-way set, 64
byte line size
64 byte line size
L2 Cache Multiplier: 1/1x (1795MHz)
< Upgradeability >
Socket/Slot: Socket A
Upgrade Interface: ZIF Socket
Supported Speed(s): 2.10GHz+
< Processor Power Management >
Processor Throttling Enabled: Yes
Throttle Range: 50% - 100%
Version: 2.00
< Power Rating(s) >
CPU Core Power: 61W (estimated)
< Sensors >
CPU Voltage: 1.65V
< Features >
FPU - Co-Processor Built-in: Yes
VME - Virtual Mode Extensions: Yes
DE - Debugging Extension: Yes
PSE - Page Size Extension: Yes
TSC - Time Stamp Counter: Yes
MSR - Model Specific Registers:Yes
PAE - Physical Address Extensi:Yes
MCE - Machine Check Exception: Yes
CX8 - Compare & Exchange 8-byt:Yes
APIC - Local APIC Built-in: Yes
SEP - Fast System Call: Yes
MTRR - Memory Type Range Regis:Yes
PGE - Page Global Enable: Yes
MCA - Machine Check Architectu:Yes
PAT - Page Attribute Table: Yes
PSE36 - 36-bit Page Size Exten:Yes
PSN - Unique Serial Number: No
CLF - Cache Line Flush Support:No
DS - Debug Trace & EMON Store: No
ACPI - Software Clock Control: No
(W)MMX Technology: Yes
FXSR - Fast Float Save & Resto:Yes
SSE Technology: Yes
SSE2 Technology: No
SS - Self Snoop: No
HTT - Hyper-Threading Technolo:No
TM - Thermal Monitor: No
PBE - Pending Break Enable: No
SSE3 Technology: No
MON - Monitor/MWait: No
DSCPL - CPL qualified Debug St:No
VMX - Virtual Machine eXtensio:No
EST - Enhanced SpeedStep Techn:No
TM2 - Thermal Monitor 2: No
SSE4 Technology: No
CID - Context ID: No
CX16 - Compare & Exchange 16-b:No
xTPR - Send Task Priority Mess:No
DAZ - Denormals Are Zero: No
< Extended Features >
SYCR - Extended Fast System Ca:Yes
EMMX - Extended MMX Technology:Yes
3DNow! Technology: Yes
Extended 3DNow! Technology: Yes
XD/NX - No-execute Page Protec:No
SMP - MP Capability: No
AMD64/EM64T Technology: No
< Power Management Features >
VID - Voltage Control: No
FID - Frequency Control: No
TS - Thermal Sensor Built-in: Yes
< Advanced Settings >
TLB Cacheable: Yes
System Ack Limit: 4 request(s)
System Victim Limit: 0 request(s)
Extended MTRR Types: Yes
I/O Type Range Registers: Yes
Top of Memory: 3E000000 (992MB)
< Machine Check Architecture Settings >
Number of Reporting Banks: 4 bank(s)
Exception Reporting Control Su:Yes
< Variable Range MTRR Settings >
MTRR 0: 00000000-3FFFFFFF (0MB-1024MB) WB
MTRR 1: 3E000000-3FFFFFFF (992MB-1024MB) UC
MTRR 2: E8000000-EBFFFFFF (3712MB-3776MB) WC
MTRR 5: E8000000-EBFFFFFF (3712MB-3776MB) WC
< Variable Range IORR Settings >
IORR 1: E8000000-EBFFFFFF (3712MB-3776MB) rdMem wrMem
< Fixed Range MTRR Settings >
MTRR 0 Range 0: 00000000-0000FFFF (0kB-64kB) WB rdIO wrIO
MTRR 0 Range 1: 00010000-0001FFFF (64kB-128kB) WB rdIO wrIO
MTRR 0 Range 2: 00020000-0002FFFF (128kB-192kB) WB rdIO wrIO
MTRR 0 Range 3: 00030000-0003FFFF (192kB-256kB) WB rdIO wrIO
MTRR 0 Range 4: 00040000-0004FFFF (256kB-320kB) WB rdIO wrIO
MTRR 0 Range 5: 00050000-0005FFFF (320kB-384kB) WB rdIO wrIO
MTRR 0 Range 6: 00060000-0006FFFF (384kB-448kB) WB rdIO wrIO
MTRR 0 Range 7: 00070000-0007FFFF (448kB-512kB) WB rdIO wrIO
MTRR 1 Range 0: 00080000-00083FFF (512kB-528kB) WB rdIO wrIO
MTRR 1 Range 1: 00084000-00087FFF (528kB-544kB) WB rdIO wrIO
MTRR 1 Range 2: 00088000-0008BFFF (544kB-560kB) WB rdIO wrIO
MTRR 1 Range 3: 0008C000-0008FFFF (560kB-576kB) WB rdIO wrIO
MTRR 1 Range 4: 00090000-00093FFF (576kB-592kB) WB rdIO wrIO
MTRR 1 Range 5: 00094000-00097FFF (592kB-608kB) WB rdIO wrIO
MTRR 1 Range 6: 00098000-0009BFFF (608kB-624kB) WB rdIO wrIO
MTRR 1 Range 7: 0009C000-0009FFFF (624kB-640kB) WB rdIO wrIO
MTRR 2 Range 0: 000A0000-000A3FFF (640kB-656kB) UC rdIO wrIO
MTRR 2 Range 1: 000A4000-000A7FFF (656kB-672kB) UC rdIO wrIO
MTRR 2 Range 2: 000A8000-000ABFFF (672kB-688kB) UC rdIO wrIO
MTRR 2 Range 3: 000AC000-000AFFFF (688kB-704kB) UC rdIO wrIO
MTRR 2 Range 4: 000B0000-000B3FFF (704kB-720kB) UC rdIO wrIO
MTRR 2 Range 5: 000B4000-000B7FFF (720kB-736kB) UC rdIO wrIO
MTRR 2 Range 6: 000B8000-000BBFFF (736kB-752kB) UC rdIO wrIO
MTRR 2 Range 7: 000BC000-000BFFFF (752kB-768kB) UC rdIO wrIO
MTRR 3 Range 0: 000C0000-000C0FFF (768kB-772kB) WP rdIO wrIO
MTRR 3 Range 1: 000C1000-000C1FFF (772kB-776kB) WP rdIO wrIO
MTRR 3 Range 2: 000C2000-000C2FFF (776kB-780kB) WP rdIO wrIO
MTRR 3 Range 3: 000C3000-000C3FFF (780kB-784kB) WP rdIO wrIO
MTRR 3 Range 4: 000C4000-000C4FFF (784kB-788kB) WP rdIO wrIO
MTRR 3 Range 5: 000C5000-000C5FFF (788kB-792kB) WP rdIO wrIO
MTRR 3 Range 6: 000C6000-000C6FFF (792kB-796kB) WP rdIO wrIO
MTRR 3 Range 7: 000C7000-000C7FFF (796kB-800kB) WP rdIO wrIO
MTRR 4 Range 0: 000C8000-000C8FFF (800kB-804kB) UC rdIO wrIO
MTRR 4 Range 1: 000C9000-000C9FFF (804kB-808kB) UC rdIO wrIO
MTRR 4 Range 2: 000CA000-000CAFFF (808kB-812kB) UC rdIO wrIO
MTRR 4 Range 3: 000CB000-000CBFFF (812kB-816kB) UC rdIO wrIO
MTRR 4 Range 4: 000CC000-000CCFFF (816kB-820kB) UC rdIO wrIO
MTRR 4 Range 5: 000CD000-000CDFFF (820kB-824kB) UC rdIO wrIO
MTRR 4 Range 6: 000CE000-000CEFFF (824kB-828kB) UC rdIO wrIO
MTRR 4 Range 7: 000CF000-000CFFFF (828kB-832kB) UC rdIO wrIO
MTRR 5 Range 0: 000D0000-000D0FFF (832kB-836kB) UC rdIO wrIO
MTRR 5 Range 1: 000D1000-000D1FFF (836kB-840kB) UC rdIO wrIO
MTRR 5 Range 2: 000D2000-000D2FFF (840kB-844kB) UC rdIO wrIO
MTRR 5 Range 3: 000D3000-000D3FFF (844kB-848kB) UC rdIO wrIO
MTRR 5 Range 4: 000D4000-000D4FFF (848kB-852kB) UC rdIO wrIO
MTRR 5 Range 5: 000D5000-000D5FFF (852kB-856kB) UC rdIO wrIO
MTRR 5 Range 6: 000D6000-000D6FFF (856kB-860kB) UC rdIO wrIO
MTRR 5 Range 7: 000D7000-000D7FFF (860kB-864kB) UC rdIO wrIO
MTRR 6 Range 0: 000D8000-000D8FFF (864kB-868kB) UC rdIO wrIO
MTRR 6 Range 1: 000D9000-000D9FFF (868kB-872kB) UC rdIO wrIO
MTRR 6 Range 2: 000DA000-000DAFFF (872kB-876kB) UC rdIO wrIO
MTRR 6 Range 3: 000DB000-000DBFFF (876kB-880kB) UC rdIO wrIO
MTRR 6 Range 4: 000DC000-000DCFFF (880kB-884kB) UC rdIO wrIO
MTRR 6 Range 5: 000DD000-000DDFFF (884kB-888kB) UC rdIO wrIO
MTRR 6 Range 6: 000DE000-000DEFFF (888kB-892kB) UC rdIO wrIO
MTRR 6 Range 7: 000DF000-000DFFFF (892kB-896kB) UC rdIO wrIO
MTRR 7 Range 0: 000E0000-000E0FFF (896kB-900kB) WP rdIO wrIO
MTRR 7 Range 1: 000E1000-000E1FFF (900kB-904kB) WP rdIO wrIO
MTRR 7 Range 2: 000E2000-000E2FFF (904kB-908kB) WP rdIO wrIO
MTRR 7 Range 3: 000E3000-000E3FFF (908kB-912kB) WP rdIO wrIO
MTRR 7 Range 4: 000E4000-000E4FFF (912kB-916kB) WP rdIO wrIO
MTRR 7 Range 5: 000E5000-000E5FFF (916kB-920kB) WP rdIO wrIO
MTRR 7 Range 6: 000E6000-000E6FFF (920kB-924kB) WP rdIO wrIO
MTRR 7 Range 7: 000E7000-000E7FFF (924kB-928kB) WP rdIO wrIO
MTRR 8 Range 0: 000E8000-000E8FFF (928kB-932kB) WP rdIO wrIO
MTRR 8 Range 1: 000E9000-000E9FFF (932kB-936kB) WP rdIO wrIO
MTRR 8 Range 2: 000EA000-000EAFFF (936kB-940kB) WP rdIO wrIO
MTRR 8 Range 3: 000EB000-000EBFFF (940kB-944kB) WP rdIO wrIO
MTRR 8 Range 4: 000EC000-000ECFFF (944kB-948kB) WP rdIO wrIO
MTRR 8 Range 5: 000ED000-000EDFFF (948kB-952kB) WP rdIO wrIO
MTRR 8 Range 6: 000EE000-000EEFFF (952kB-956kB) WP rdIO wrIO
MTRR 8 Range 7: 000EF000-000EFFFF (956kB-960kB) WP rdIO wrIO
MTRR 9 Range 0: 000F0000-000F0FFF (960kB-964kB) UC rdIO wrIO
MTRR 9 Range 1: 000F1000-000F1FFF (964kB-968kB) UC rdIO wrIO
MTRR 9 Range 2: 000F2000-000F2FFF (968kB-972kB) UC rdIO wrIO
MTRR 9 Range 3: 000F3000-000F3FFF (972kB-976kB) UC rdIO wrIO
MTRR 9 Range 4: 000F4000-000F4FFF (976kB-980kB) UC rdIO wrIO
MTRR 9 Range 5: 000F5000-000F5FFF (980kB-984kB) UC rdIO wrIO
MTRR 9 Range 6: 000F6000-000F6FFF (984kB-988kB) UC rdIO wrIO
MTRR 9 Range 7: 000F7000-000F7FFF (988kB-992kB) UC rdIO wrIO
MTRR 10 Range 0: 000F8000-000F8FFF (992kB-996kB) UC rdIO wrIO
MTRR 10 Range 1: 000F9000-000F9FFF (996kB-1000kB) UC rdIO wrIO
MTRR 10 Range 2: 000FA000-000FAFFF (1000kB-1004kB) UC rdIO
wrIO
MTRR 10 Range 3: 000FB000-000FBFFF (1004kB-1008kB) UC rdIO
wrIO
MTRR 10 Range 4: 000FC000-000FCFFF (1008kB-1012kB) UC rdIO
wrIO
MTRR 10 Range 5: 000FD000-000FDFFF (1012kB-1016kB) UC rdIO
wrIO
MTRR 10 Range 6: 000FE000-000FEFFF (1016kB-1020kB) UC rdIO
wrIO
MTRR 10 Range 7: 000FF000-000FFFFF (1020kB-1024kB) UC rdIO
wrIO
< PAT Settings >
PAT 0: WB
PAT 1: WC
PAT 2: UC-
PAT 3: UC
PAT 4: WB
PAT 5: WC
PAT 6: UC-
PAT 7: UC
Tip 210: Mainboard supports faster CPUs, so the CPU
can be upgraded when needed.
tip.
<< System BIOS >>
< General Information >
Manufacturer: Phoenix Technologies, LTD
Version: 6.00 PG
Plug & Play Version: 1.00
SMBIOS/DMI Version: 2.20
(EE)PROM Size: 256kB
< General Capabilities >
Can be Updated/Flashed: Yes
Can be Shadowed: Yes
Is Socketed: Yes
Supports Plug & Play: Yes
Supports ESCD: Yes
Supports Enhanced Disk Drive: Yes
NEC PC-98 Spec Compatible: No
Supports APM: Yes
Supports ACPI: Yes
Supports Smart Battery: No
< Boot Features >
Supports Selective Booting: Yes
Supports CD/DVD Boot: Yes
Supports PCMCIA/CardBus Boot: No
Supports LS-120 Boot: Yes
Supports ZIP Boot: Yes
Supports i2o Boot: No
Supports FireWire/1394 Boot: No
Tip 201: System BIOS is old. Check for an update.
Tip 207: A SMBIOS/DMI 2.3 or later compliant BIOS is
recommended. Check for a BIOS update.
Tip 212: BIOS can be shadowed so check whether it is.
Tip 211: BIOS is flash-able and socketed so it can be
tip.
Old 12-18-2005, 10:32 PM
Default Re: Sandra report
As I posted in your other thread.. you don't have a QUALIFIED FireWire card installed.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 12-18-2005, 11:02 PM
thanks Rail,
I posted that by accident in the mac forum first. When I realized it, I was putting it in the right forum as you were responding...
Thanks for looking at it! With the hardware buffer increase/decrease errors; is not having a "qualified" firewire port a known issue? For the past two years those have been the only error prompts I've been getting; but have been making it impossible to create a positive work flow. Thanks for your time and help!!!
Old 12-18-2005, 11:04 PM
Yes -- you need a FireWire card which is qualified and has a compatible chipset -- your onboard VIA chipset FireWire card is definately a problem.
You didn't list your Digidesign hardware so I assume you have an 002.
Rail
Platinum Samples
sandra report vin7 Windows 3 03-26-2014 03:47 PM
Sandra report mickeyrouse Getting Started 3 01-13-2014 05:57 PM
Sandra Report keithaska 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-23-2010 12:43 PM
Thanks! Sandra Report stevegrisham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-08-2009 09:26 AM
Sandra Report Help Please JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-09-2007 05:52 AM
