re:logic and avid interface
Hi guys, does anyone know if you can use Avid HD interface with Logic 10?
Thanks for the help.
JAMAICAN I IS 2008 2009 and 2010 Mac Pro 8 core with 64 GIG memory with 9 terabyte of hard drive space blue ray player HDX 1, 2 16X16 interfaces sync I/O. |
Re: logic and avid interface
Yes you use the CoreAudio support to do this. If Pro Tools is not already installed just install the drivers for your hardware. You of course get no DSP/HDX Processing and you only get to use the first HDX card. You should go read all the documentation on this.
It does not show up at all in Audio/MIDI setup? As an option within the aggregate IO device?
See if it helps http://avid.force.com/pkb/articles/e.../HDX-CoreAudio Failing that I would try reinstalling the appropriate HDX drivers. |
While launching Protools, hold down the "N" key. Hopefully that will bring you to a box where you can choose HDX.
If this works, you won't have to do it again, as HDX should show up from now on. |
Pro Tools?
I am not sure how any of that is going to help use the HDX interface in Logic Pro. |
Oops, didn't see that.
I find it strange that no one from Avid has said anything or why there is nothing in the knowledge base about this
I know this should work, but don't have a HDX system to test it on here. |
Can Avid HEAT run in PTHD 10/11 without an Avid Audio Interface or HDX Card? | hatepop | Pro Tools 11 | 1 | 12-19-2013 01:26 AM |
re: RX3 with avid interface | 2224 | Tips & Tricks | 24 | 10-26-2013 03:36 AM |
Avid 96 i/o interface - £349 ! | Ru_C | Buy & Sell | 0 | 09-03-2013 09:19 AM |
Using Avid interface + Mac sound | Picture Start | macOS | 1 | 01-15-2012 09:24 AM |
PT9 HD with a non-Avid interface? | SirLexelot | Pro Tools 9 | 6 | 11-06-2010 02:51 PM |
