RE:waves tune
Is anyone using waves tune in 10 and if so are you having a problem where the vocals are delayed??
I am having this problem and I don't know how to fix it. Any help would be appreciated.
JAMAICAN I IS 2008 2009 and 2010 Mac Pro 8 core with 64 GIG memory with 9 terabyte of hard drive space blue ray player HDX 1, 2 16X16 interfaces sync I/O. |
Re: waves tune
If you're trying to actually record with that plugin on, then there will be a delay because that plugin has a lot of latency. Any of the pitch correction plugins do, including Autotune and Melodyne. You're better off using them after the fact during mixing.
However, Autotune has now come out with Autotune Live, a separate plugin with no latency for those who want to record with it on. |
Re: waves tune
Does delay compensation correct the shift? I try to keep it on, regardless if I'm hearing any problems.
Re: waves tune
Yes, it does, which is fine when you're mixing, but for trying to record with it on, the latency will be a problem.
Re: waves tune
Re: waves tune
Make sure you have delay compensation turned on, and set to Long. If that doesn't take care of it, then set it to maximum.
Alternatively, you could use the Audiosuite version, and not mess with any of that. |
Re: waves tune
Thanks nst7, that seem to have made a difference, waves support wanted me to nudge the file in time to resolve the issue.
Re: waves tune
Yes you can nudge your clip(s)... that's what I do.
Or you can export your clip(s) to Audio and nudge of course, and you won't have to grapple with this every time you open your project. I "think" they call this "printing?" Waves Tune isn't perfect, but when you learn the work-arounds it becomes easier. |
Re: waves tune
I'm having the same problem. What does it mean to export audio? How do you do that? Thanks
Pro Tools 10.3.9 HP 8540w laptop Windows 7 Pro SP1 64bit 16gb 1.7 ghz 320 GB Internal HDD Samsung 840 EVO Audio SSD 250 GB Focusrite Scarlett 2i2 Amplitube 3 Reason 5 MAudio Keystation 61es |
Re: waves tune
Export means sending a file or files to another place, go to yor Manuel and look it up,you will get a better understanding than what I am giving you.
Waves Tune and Auto-Tune Unhappy With HDX? | Logichead | Pro Tools HDX & HD Native Systems (Mac) | 2 | 11-25-2012 11:42 AM |
I need help with Waves Tune LT | fly-deluxe | General Discussion | 3 | 02-03-2012 12:03 PM |
Help! re. Waves Tune | ronstephens | Tips & Tricks | 2 | 09-21-2011 12:58 PM |
using waves tune lt | Travis09 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-11-2009 12:51 PM |
Waves Tune is out! | Cliffy_Boy | Pro Tools TDM Systems (Mac) | 90 | 11-13-2005 10:28 AM |
