Go Back   Avid Pro Audio Community > Announcements > Technical Alerts
Old 12-13-2013, 06:11 PM
Artist PM's Avatar
Artist PM Artist PM is offline
Default EUCON/EuControl 3.1 Now Available
EuControl 3.1
EuControl is an application that runs Artist Control, Artist Mix, Artist Transport, and Artist Color media controllers and communicates with your software applications. This package installs EuControl and other necessary software. EuControl supports one Artist Control, one Artist Transport, one Artist Color, and up to four Artist Mixes.
What's New
  • Mac OS 10.9 “Mavericks” support.
  • New Firmware Update - this firmware includes an update that resolves the slow/broken surface discovery after a workstation restart.
    • Note: Direct Connect using Thunderbolt to Ethernet is not supported. It is recommended to use USB to Ethernet adapter instead.
  • Artist Banking Improvements: Artist Mix + Control banking combined should default to 8 not 4. Banking now behaves as expected when nudged away from multiples of 8.
  • Input knob set in Pro Tools is now reversed at the top level. In Normal mode the Input label now appears without having to page right several times.
  • VCA Group meters now update correctly when adding a mix group to the VCA Master track in ProTools.
  • EQ knob set on Artist Control is re-mapped to be more intuitive. Lows are now located on the left side, and highs are on the right.
  • Chan mode parameters would display blank on OLEDs that did not have an active channel; OLED displays now display all parameters correctly.
  • The “end” button on Artist Mix would not work in systems with both Artist Mix and Artist Control combined. This now works for all configurations.
  • Wheel Mode LED (Jog/Zoom) would not turn off when disabling a wheel mode. LED nowturns off correctly when no wheel mode is active.
  • Hidden Tracks performance and stability improved on all surfaces.
  • Show Info display was corrupt on Artist Mix (Windows only).
  • Insert knob top would fail on 1st press in Normal Mode on Artist Mix.
  • Plug-in window would not open when editing a plug-in that was previously opened in Pro Tools from Artist.
  • Plug-in window in Pro Tools now follows channel selection in EQ/DYN knob sets. This was previously fixed in Inserts knob set, and now also works for EQ and DYN knob sets.
OS Compatibility
  • Windows 7 64-bit
  • Windows 8 64-bit
  • Mac OS 10.8.x
  • Mac OS 10.9.x
PLEASE NOTE THAT WINDOWS 32-bit IS NO LONGER SUPPORTED
NOTES
  1. Windows users: EUCON Discovery is no longer used and will no longer exist in the Windows Task Tray. You can select the desired Network Port to be used for EUCON in Control Panel> EUCON using the drop down menu at the bottom. After selecting a new Network Port you must restart your system.
  2. Network setup: If working on a system with multiple network connections such as an active AirPort and Ethernet connection or 2 or more NICs, each network needs to be set to its own Subnet. If two network connections are active and have the same Subnet, EUCON will default to publish to the network that was enabled first on your system. To avoid confusion, always ensure that each network connection is on its own isolated Subnet.
Discussion Forum
Artist Series
HTML code is On
EUCON/EuControl 3.1 available Artist PM Artist Series 43 05-13-2015 02:15 AM
Updated Eucontrol to 2.7 and upgraded to Mountain Lion 10.8.2. Eucon now broken. Focuret macOS 0 03-08-2013 09:21 PM
No Eucon commands visible in Eucontrol software 2.6.2 (Win7 64bit, PT 9.0.5) Elmobe Artist Series 0 11-23-2011 02:35 AM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
