Old 10-09-2018, 09:36 AM
Rattleshock Rattleshock is offline
Default C24 fader not providing full range
Greetings,
I have searched the forum, but have not found my specific problem in any of the threads. One fader is not moving past 0db when reading from Protools. It will physically move, but won’t register any change to Protools or from Protools in the upper 6db range. Up to Zero on the fader it is fine. Additionally, the level shown on the C24 is approx 6db lower than what Protools shows, regardless of fader position. Any ideas on how to fix this? Should I just order a new fader?
Thanks in advance,
Glenn
Old 10-09-2018, 10:17 AM
Default Re: C24 fader not providing full range
have you run all the fader tests in the Utilities menu on the C24? That should tell you what's going on - probably you'll need to replace the fader. Prepare for the removal of many many many screws on the back panel!
rich@richbreen.com
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 10-09-2018, 09:05 PM
Yes, I have completed all system tests in the utility menu. It’s only the one fader. It is apparent that the upper portion of the fader travel is ‘dead’ or unresponsive. It is odd though, because up to the zero mark it is fully functioning. Only the upper 6db of travel is a dead zone.
Does anyone have recommendations on where I can purchase a fader replacement that will be compatible? I am in Canada, so if there were a domestic supplier, that would obviously be my preference.
Thanks for the reply!
Glenn
Old 10-10-2018, 08:55 AM
sound_bites sound_bites is offline
you’ll need this:
https://www.fullcompass.com/prod/225...r-sc48-003-c24.
You can probably find one on ebay as well. Anyway, it’s the SC 48 motorized fader.
Cheers
Old 10-10-2018, 10:53 AM
Thank you!
Old 10-12-2018, 08:33 AM
Just a quick update. I have successfully ordered a replacement fader for the C24 and am waiting for it's delivery.
Old 10-13-2018, 08:47 AM
Great! Hope it solves the problem.
How to record a FULL RANGE guitar sound? jclark5093 Tips & Tricks 27 12-24-2017 10:44 AM
11R Tube Power Amp/Speaker Cab vs. Full Range Powered Monitor Barry Johns Eleven Rack 22 12-09-2011 05:01 PM
Five Inch Full Range Monitors GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-13-2007 06:42 PM
Moving large speakers(full range) NoRush General Discussion 2 02-04-2006 07:30 PM
OT: Frequency response on full range monitors. pindebraende 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-28-2003 10:27 AM
