Re: Can't import audio in PT 12
Thanks for the reply!
The error message actually comes up before I can get far enough to select a file. From a blank, new session, if I click "Import - Audio " the error message immediately comes up. |
The error message actually comes up before I can select a file of any sort - it happens as soon as I use the key stroke to import audio, or go to the file drop down and select "Import - Audio" It's certainly got me spinning. |
At this point, I'd try a clean reinstall of Pro Tools since the error seems to be pointing to a command in a Pro Tools directory. Of course, have a backup plan!
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
agreed, it sounds corrupted ... what did you do .. try to use it !!!!
Also check for illegal characters in the hard drive names aswell as not too long names as PT trips up by that.
Best Regards Christopher #thestruggleisreal ————————————— South Side Music Group WEBHOME ————————————— |
#16
Can you *record* audio in this session at all? Can you successfully save it after recording? Is it only specific audio files that won't import or *any* audio (different sample rates/formats)?
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
#17
I can record and save everything else as normal. The only thing I've found thats not working is the import audio function. The Import Audio function gives me an error as soon as I click it, before I get to tell it what I'm looking to import at all. And this all happens regardless of what hard drive the session comes from (Root, and several different external drives with legal names).
I can open the same session on another computer, and import audio into the session, come over to my studio computer - and use the session as normal, I can record, edit, export, twist, taco, jump, spin, bounce, and even input monitor. But on this computer, I am forbidden from the Import Audio menu for whatever reason. Any final thoughts before re-installing PT? |
#18
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
#19
I'm curious though what happens if the OP selects a different Playback Engine?
#20
Import Video - Audio Import Option Disabled | sarcanon | Pro Tools 12 | 2 | 06-14-2016 05:12 PM |
Does "Automatically Copy Files on Import" work with Import Audio command? | leftalive | Pro Tools 10 | 3 | 04-17-2013 09:35 PM |
Import Session Data with out Audio import | disinfor | Pro Tools M-Powered (Mac) | 7 | 11-14-2010 11:44 AM |
Import Audio search window results will not import | BA Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-25-2008 09:00 AM |
Re: Import Audio or Bounce to Disk then Import | filosofem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-10-2005 03:52 PM |
