#21
Re: Win7 + HD 8.0.1
i haven't had one 6031 in windows 7
-s0nguy |
#22
Re: Win7 + HD 8.0.1
Devices list of my computer:
MB: Foxconn Renaissance X 58 Memroy: Kingston DDR 3 1333 2Gx3 Video Card: ATI 4650 Hard disk:West Data 1T x 2 for Raid 0, Segate 160G x 2 for the system and backups. CPU: I 7 940 with hyperthred off. OS: Win 7 64 bit Ult... I'm running PT 8.0 CS3 now, if I use too many MCDSP plugins, there would be some pops and clicks. If I run 8.0.1, pops and clicks are gone, but the 6031 came. 6031 would jump out few time per hour. |
#23
Re: Win7 + HD 8.0.1
I really gotta say... so far 8.0.1 is stable as hell on my Dell 690.. running win7 64 bit.
-s0nguy |
#24
Re: Win7 + HD 8.0.1
I haven't finished installing everything yet but I know that the following plugins that don't work with 64 bit Windows 7
Cranesong Phoenix Amp Farm Echo Farm PT hangs when it tries to load these. I suspect they have issues with the 64 bit ilok driver. Sonnox plugins were tricky to install. They get confused about the version number of the ilok driver, needing 5.8.5 and thinking that the latest version (5.8.11) is actually 5.8.1. I uninstalled the ilok sriver completely, installed the Sonnox plugins and then upgraded the ilok driver back to 5.8.11. All good. Kontakt 4 is fine, you just can't use it standalone because it needs a 64 bit ASIO driver, but it works fine in Protools. Thought I'd share, may save you someone some pain. |
#25
Re: Win7 + HD 8.0.1
-s0nguy
I have a Del 690 also and I am having issues with my setup. I am wondering what kind of video card do you have? I have the original NVIDA Quatro FX 3500. I got pro tools to instal and update but when it opens it says "...you have 0MB allocated..." could this be the video card prob or what? -protoolseng |
#26
Re: Win7 + HD 8.0.1
[QUOTE=lennieh;1487933]I haven't finished installing everything yet but I know that the following plugins that don't work with 64 bit Windows 7
Cranesong Phoenix Amp Farm Echo Farm PT hangs when it tries to load these. I suspect they have issues with the 64 bit ilok driver.QUOTE] Try installing ProTools as well as the affected plug-ins with the "run as administrator" option. Worked for me!
Windows 10 Pro x64 Avid HDX running PT Ultimate 2020.x ASUS WS x299 SAGE 10g Intel i9-10980xe 64 GB DDR4 3200 RAM Matrox C420 Avid Artist Mix |
#27
Re: Win7 + HD 8.0.1
hrmm...I have that same card and havent had that issues at all. did you do a clean install windows and all?
-s0nguy Quote:
#28
Re: Win7 + HD 8.0.1
I get slightly different behaviours from the installers; when I the Phoenix installer ( I tried it as administrator) Windows reports that the installation failed. When I run the Amp Farm installer it says I haven't got PACE drivers installed, when I obviously do or elese nothing else would work. Then if I start PT with either of these plugins installed, Protools just hangs when it hits the dodgy plugin... |
#29
Re: Win7 + HD 8.0.1
I bought one from ATI X550 for $15 ;-) and now I'm tracking and mixing session with more than 50 audio tracks and VI's and everything works stable as my Nuendo before ;-) so far on my HD1-heavy on RTAS of course with HD1... First, when I was using NVidia, 6031 error was jumping out every 5 seconds..and Drumagog was out of time very much..and basicaly whole system was not stable.. The rest of my system is:Q6600, Asus P5KC,DDR2 8500 Geil (run on 800mhz because of chipset limitation with 8Gb of RAM),Windows 7 pro 64 bits.... Installed PCI Core card in second slot from graphic card,because of space limit of my case etc.At last works nicely
Musician,Producer etc.. PT|HD Ultimate Native , UAD-2 Octo x2 , Win 10 Pro 64 bit, AMD ThreadRipper 3960X (24 cores 3,7Ghz (48 threads), 64 GB G.Tech DDR4 3200MHZ ,Gigabyte TRX40 Designare (with Thunderbolt), (Philips 40'LED screan) , Samsung 24" LED 2x192 I/O, Nuendo 4.3, Wavelab 6, Halion 3.5, Yamaha 02R96V2, AvalonAD2022, AvalonVt737sp etc... www.MrPollack.pl ,www.facebook.com/polak.bros.studio |
#30
Re: Win7 + HD 8.0.1
No, I'll give that a try later.
I tried re-installing PT last night, running everything as Administrator, but it made no difference. I just allowed the ilok driver install to do its own thing, so I guess I have a 64 bit driver, but it seems to be compatible with 32 bit apps. If you have Phoenix running, what version of the ilok driver do you have? I'm on 5.8.11. Anyone get the McDSP plugins to install? |
mac pro 1.1 for 64 bit win7/hdx | klaukholm | Pro Tools HDX & HD Native Systems (Win) | 6 | 12-11-2013 12:41 PM |
Here goes nothing - Bye Bye XP, hello Win7 | markus44uk | Windows | 17 | 10-02-2011 07:51 AM |
big BUG in PT8.03 under win7 X64 | 32768 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-05-2010 03:47 PM |
Win7? | Fullsound Recording | Pro Tools TDM Systems (Win) | 10 | 04-30-2010 09:44 AM |
GR4 PT 8.0.1 Win7 | jazzmandan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-01-2009 06:19 PM |
