Old 02-25-2020, 10:41 AM
Dabbler Dabbler is offline
Default Drag and Drop Audio from Workspace issue
Hi.
Pro Tools Ultimate 2019.5.0 on iMac Pro Mojave 10.14.5
I am trying to drag and drop a bunch of audio files which are numbered 1 - 40 into a template with corresponding tracks also numbered 1 - 40 and for whatever reason, whenever I do this Pro Tools seems to scramble the order so that I have to go through and manually move every audio file to the track to where it should be.
It doesn't matter if I grab all 40 tracks or just 3 of them....they don't stay in alpha/numeric order. Huge time killer.
Say for example I have 5.1 interleaved audio files with the following file names:
Stem 1 Live Brass
Stem 2 Synth Brass
Stem 3 Live Strings
Stem 4 Synth Strings
Stem 5 Hi Perc
Stem 6 Lo Perc
Stem 7 Synth Perc Loops
In the workspace they are in numeric order Stem 1 to Stem 7, top to bottom.
Grab all 7 of them together and Drag/Drop to Pro Tools Session with 7 corresponding 5.1 Audio tracks, also numbered 1 - 7 (but track names should be irrelevant). This is what I see:
Track 1 Live Brass = Stem 3 Live Strings
Track 2 Synth Brass = Stem 1 Live Brass
Track 3 Live Strings = Stem 5 Hi Perc
Track 4 Synth Strings = Stem 7 Synth Perc Loops
Track 5 Hi Perc = Stem 2 Synth Brass
Track 6 Lo Perc = Stem 4 Synth Strings
Track 7 Synth Perc Loops = Stem 6 Lo Perc
Seems pretty random, but it is consistent insofar as the "scrambled" order is the same every time if I Quit Pro Tools and then re-open the session and do it again. Also, it doesn't matter if I only grab, for example, any three consecutive Audio files...they show up out of order top to bottom in the Pro Tools Session.
Anyone see this and know what's causing it? I've trashed Prefs/rebooted and restarted protools and still have the issue.
Any ideas would be much appreciated.
Old 02-25-2020, 11:31 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Drag and Drop Audio from Workspace issue
Hi, Does it matter if you drag them from a folder or from the clips bin?
Help Us Help You
Chris
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Pro Tools HD 2020.5
Old 02-25-2020, 02:48 PM
From a folder in the finder or from the clips bin it seems to work as I would expect.
That said, I was hoping to find a fix for the problem and not a work around....
Old 02-25-2020, 03:02 PM
capt kirk capt kirk is offline
On my system, PT10, when I drag a clip group from the workspace, only a few of the tracks come onto the timeline, but then if i re-drag it from the clipbin, its proper...
www.kfaudio.ca
JFreak JFreak is online now
If it is a bug then fix would be newer PT version where the bug has been squashed. As you are on Mojave, try 2019.10 instead of the now current 2019.12 which is released for those who need to run Catalina. Some time soon 2020.x should be out too. If that doesn't help contact Avid Support and explain the situation you think is a bug.
Old 02-25-2020, 11:02 PM
cwsand's Avatar
Oh I wasn't thinking of it as a workaround - that's how I usually work.
Help Us Help You
Chris
PreSonus Digimax LT
Pro Tools HD 2020.5
Run as administrator issue - either drag and drop or elastic audio broken tcolvinMS Pro Tools 11 10 02-27-2015 08:17 AM
Can't Drag and Drop from Workspace blizzard Windows 8 02-13-2015 08:39 PM
Drag and Drop from Workspace VERY Slow gfcurtis macOS 36 01-29-2015 09:08 AM
WorkSpace Drag and Drop Not Working in PT11? quantise Pro Tools 11 0 08-14-2013 07:29 AM
Workspace drag and drop issue ZeSnail Post - Surround - Video 3 12-25-2011 08:11 AM
